Home > Technical (L322) > coolant pressure
mattyboy
United Kingdom 2003 Range Rover Vogue 4.4 V8 Oslo Blue
coolant pressure
Does anyone know what the running pressure of a 4.4 v8 coolant system should be? I know they run higher than most to increase the coolant temp, but what should it be when hot?
kind regards
Post #144795 5th Oct 2012 9:53am
Is it not marked on the coolant bottle cap?
Post #144799 5th Oct 2012 10:10am
on rave? ... - .- -.
Post #144826 5th Oct 2012 1:09pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
As above it should be on the cap. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #144894 5th Oct 2012 7:24pm
mattyboy
mine just has 200 on it???
Post #145265 8th Oct 2012 9:30am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
2 atmospheres.
2.00 bar!
Post #145269 8th Oct 2012 9:37am
200 kPa which equates to 29psi or 2Bar.
Interestingly a td6 runs at 140kPa.
Post #145275 8th Oct 2012 9:59am
Higher pressure allows for higher temperatures before the water boils and turns to steam
Post #145284 8th Oct 2012 10:43am
mattyboy
Thanks for that, the reason I asked was last week my header tank burst open (which I know is a common fault) So I thought i'd just check the system pressure to make sure that it wasn't caused by HG failure. Which I'm pleased to see it wasn't!
thanks again
Post #145289 8th Oct 2012 11:34am
