Home > Maintenance & Mods (L322) > Wiring up Rear Reflectors as Rear DRL's
Page 3 of 4 <1234>
Part 2 Photo Tutorial ready and LEDs up and running (well, nearly....)
http://www.fullfatrr.com/gallery/displayim...amp;pos=12
Need advice on rear fusebox and piggyback fuse holder thing.
All the fuses/connectors in the fuse block appear to be live all the time.
If I use an empty fuse connector with the piggyback (with a fuse in the top slot in line with the cable) one way round I get no power, the other way round I get power. If piggyback used with two fuses I get power. This all with ignition off, keys out.
Looks like I need to track down an ignition live on this side of the car, or dive back to the left hand side where I know I have one for the radio/tv/satnav. Help and advice appreciated on this (and on using the piggyback correctly).
[EDIT] @ stan - had your supper yet ? Wink .
Post #151705 17th Nov 2012 5:26pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I really like this.
Well done mate.
Post #151708 17th Nov 2012 5:50pm
alan
2002 Range Rover Vogue Td6 Alveston Red
Looks good Thumbs Up
Post #151714 17th Nov 2012 6:26pm
Joe, this is the wiring diagram for the rear fuseboard and it definitely shows fuse 8 as ignition controlled and un-used.
As is fuse 5 also.
I haven't checked this on the car but the diagrams are usually accurate.
You could piggy back on any of the ignition controlled fuses it doesn't have to be unused.
Are your leds white or red?
Post #151717 17th Nov 2012 6:39pm
@ nicedayforit
Definitely RED (sorry about rubbish photo)
I'll give Fuses 5 & 8 another go tomorrow, but no matter what I tried they were either on without ignition or just not on at all.
Is it something to do with my earth connection. I am using the one where the trailer leads come in in the spare tyre area. There is a "white" wire connected there which I "piggybacked" onto (not to be confused with other piggybacking references) Smile .
Post #151744 17th Nov 2012 9:06pm
Try putting an earth wire onto one of the bolts on the metal work above the fuseboard. Thats what I used for my supplementary reverse lights.
Post #151745 17th Nov 2012 9:14pm
Hmmm... looking at my electrical circuit diagrams shows Fuse 8 on battery and only Fuse 5 on Ignition? Different for LHD/US ?
Post #151746 17th Nov 2012 9:25pm
That's interesting.
I can't explain the diference between the two wiring diagrams.
Where does your diagram originate?
Both diagrams show fuse 5 as ignition controlled though and unused.
Might have a look at my car tomorrow and check 5 and 8.
Post #151752 17th Nov 2012 9:54pm
Joe90 wrote:
@ Craig
You are not confusing the ones down on the bumper with the ones in the rear light cluster are you?
If not, on the bumper, you simply shove a flat bladed screwdriver in at the top of the reflector and lever out. They are held in place with a spring clip. Powerfuluk do a video on gaylander which has much the same reflector.
See photos in gallery for splitting the reflector (red bit) from the backing panel (grey bit).
Ahh Joe... Now i feel daft! I thought you were going to stick LED's on the outside of your rear lights over the red reflectors...
The results thus far look good pal, just got the wrong end of the stick Rolling Eyes
Craig Bow down
Post #151754 17th Nov 2012 10:01pm
@ nicey
I think mine is My2003 NAS LHD so V8 only, hence the difference?
@ Craig, get some kip, I need you fit and well to make up those full length fins Wink .
Post #151759 17th Nov 2012 10:44pm
i'm off to buy a hat..... Wink ... - .- -.
Post #151785 18th Nov 2012 9:03am
Looks interesting.. But is it legal?? Could they be confused with brake lights on all the time or even fogs. The most annoying thing is when it is raining and some prat has left, or put, their fog light on. I'm thinking you might get pulled over for this. I suppose it depends how bright they are tho'.... Previously..
Post #151792 18th Nov 2012 9:52am
mjdronfield
They look good, but I too wondered about the fog/brake confusion thing.
Am I right in thinking DRL's should go off when you put the sidelights/normal lights on ? Obviously depending how they are wired.
In which case, you'd normally have some lights on in rainy / bad conditions, so the rear DRL's would be off.......if you see what I mean.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #151797 18th Nov 2012 10:18am
But lit rear reflectors are not fog or brake lights.
If stopped you can easily demonstrate this by applying the brakes and switching on the fog lights.
Post #151802 18th Nov 2012 10:52am
mjdronfield
Agreed. But I was thinking about the masses out there, who struggle to steer and use the pedals at the same time, let alone figure out what the lights might be.
Obviously if they are not too bright, there need not be an issue, but you know what people are like, if they are fairly bright, they'll flash you and all sorts of stuff. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #151804 18th Nov 2012 11:01am
Page 3 of 4 <1234>
