Home > Maintenance & Mods (L322) > sunroof adjustment |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
hi does anyone know how tro adjust the sunroof to close flush with the roof im gatting wind noise |
9th Oct 2012 9:06pm |
GTJones Member Since: 23 Aug 2012 Location: Carmarthenshire Posts: 35 |
Hi Extract from the Repair Manual - hope that helps Initialisation Initialising the sunroof allows the control unit to learn the end positions of the motor's travel. The hall sensors provide pulses for motor rotation, the control module counts the pulses and determines where the panel is by memorizing the stored pulses. If the system is not initialised, the sunroof will only operate in the tilt up and slide close positions. Initialisation Procedure Pressing and holding the sunroof switch in either the tilt up or slide close positions for 15 seconds momentarily operates the sunroof motor. The control module memorizes the pulses from the hall sensors on the next activation of the motor by driving the panel to its end run positions. The control module senses an amperage increase and determines the end run position. The counted number of pulses is then used as the basis for calculating the panel position. Gary |
9th Oct 2012 9:24pm |
