![]() | Home > Technical (L322) > Is V-Power Diesel worth it for a TDV8? |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I tried one tankful, no noticeable difference in my consumption. Might possibly have been slightly smoother,but that's not definitive. Extra 8 quid a tank Graham
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
Same here,tried it last week , no difference. 2011 4.4 TdV8 Nara Bronze |
Unlikely to make much performance difference as the engined is tuned to the 95 Octane but it will make a difference to the MPG long term and should improve long term wear and keep the injectors clean due to the additives. |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
This is diesel - cetane not octane (and not 95!). A higher cetane number means shorter ignition delay and (in theory) more complete combustion of the fuel leading to increased power, economy and smoother running. Presumably most "premium" diesel also has some blend of additives in it to clean injectors etc. Can't say I've noticed any obvious difference in performance or economy on the odd occasion I've put it in. |
It was late and was thinking Petrol but you know what I meant.... |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
In the past I've used an additive, which is designed to clean injectors and boost the cetane rating of the diesel.
I think if you use a "premium" fuel or additive, it will take a while to see the effect. First of all the cleaning of the fuel system and sometimes even cylinders/exhaust takes a while. I would expect it to show a difference after a few tanks (say 3 to 4) of continuous running on premium fuel, depending on the age of the car. It takes a bit of time to clean the fuel system and engine.
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 268 ![]() ![]() |
I've decided to run it on V-Power for the first few tanks to flush the system through and then revert to the regular stuff.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I'd be pleased to see anything over 25mpg |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
I'd take 19 mpg... |
The last one did 17mpg with the wind behind it. |
Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181 ![]() ![]() ![]() |
They do vary a bit then, mine hovers around 27mpg, and I do mostly steady motorway driving. Happy enough with that as thats what I was getting before from the Touareg but 30mpg would be brilliant... how in God's name do you get it to do that!? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
the only difference I noticed was in my wallet |
