![]() | Home > Maintenance & Mods (L322) > Bonnet Release cable snapped |
Im hoping its just at the release handle end BUT has anybody replaced theirs?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
any help?
Thats the one i found stan but no details on the trim piece removal or any pictures.
what about this..
Stan that is the super post i tried looking for!!
lucky you ![]() you're welcome Will... ![]() Y. O. L. O. . |
a very true double entendre |
KP, have a look around for a motorbike cable lubricator. They clam around the end of the cable and allow you to squirt lubricant into the cable with a spray can. The lubricant can go quite far into the cable as the outer cable is "sealed shut" to the lubricant goes into the cable instead of all over the place. MY 2010 5.0 SC Galway green and sand interior!!
Cheers Eb will have a mosey for it |
Hi mate. To get to the cable open the drivers door, pull the mat out if you have them, then lift the kick plate up. Think there are 4 clips holding it, then pull the black handle surround straight towards the back of the car. The handle will stay where it is and you will find the snapped cable. Hope you can follow that???? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Will, that is the one I have as well ! MY 2010 5.0 SC Galway green and sand interior!!
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
My cable broke last week, so ordered one. Tried fitting it today, I'd ordered a LHD cable! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Will, often the tit comes off the end of the cable in the handle pal... |
Hobbyist Member Since: 03 Feb 2014 Location: United Kingdom Posts: 4 ![]() ![]() ![]() |
well thanks to all who have posted here, I had the problem and reading this thread helpd me solve the proble with a small loop of cable, with plactic tube over it, attached to the broken handle end of the cable with an electrical screw type connector. |
