|  | Home > Technical (L322) > mapping |
| fil b Member Since: 08 Nov 2013 Location: poole Posts: 14      |
 Hi all, is it safe remap a vogue 2003 with 103000 on clock ? | ||
|  30th Jan 2014 7:26pm |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204      | Diesel   | ||
|  30th Jan 2014 7:27pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878    | dont waste your money, i had my td6 done and it didnt do anything...you'd be better off putting an egr blanking kit on.. | ||
|  30th Jan 2014 7:32pm |
| fil b Member Since: 08 Nov 2013 Location: poole Posts: 14      | yes it ia a diesel td6 | ||
|  30th Jan 2014 7:38pm |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204      | As Stan said   | ||
|  30th Jan 2014 7:53pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000      |
|  30th Jan 2014 8:28pm |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204      | With over 100K on the clock wouldn't it be a big NEW strain on the engine   | ||
|  30th Jan 2014 8:30pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000      | I see where you are coming from, but the gearbox issues are not torque related, and I understand there are less turbo issues after remap - though I did read that on a BMW forum, and can't remember which one. Something to do with the way it spools up.
|  30th Jan 2014 8:40pm |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204      | mjdronfield
|  30th Jan 2014 8:46pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000      | Yes, also a valid route to a quicker more driveable Ffrr. Especially as the tdv8's are getting cheaper now.
|  30th Jan 2014 8:54pm |
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818    | Yes it is worth it depending on who's map it is. The TD6 is a very under stressed engine and BMW even did their own power upgrade. I had a td6 from new several years ago and put over 80k miles on it with absolutely no issues at all. I went with a JE Map after thorough research and also looked at DMS, Autologic, Overginch etc.
|  30th Jan 2014 8:55pm |
| Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591      | As Stan says I would do the EGR blanking thing, seems to work for everyone, the TD6 is what it is, if you want an X5 then buy one, IMHO   | ||
|  30th Jan 2014 8:56pm |
| RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186    | I have had my td6 remapped after about a month of owning it with 90k on the clock. I am very happy with the results more power, better mpg and it does not change down quite so quick when going under load. As it has been stated they are very under tuned in the ffrr.
|  30th Jan 2014 9:50pm |
| Posting Rules
 Got rid of it as it was
  Got rid of it as it was   , my TD6 will stay as intended
