Home > Maintenance & Mods (L322) > Bleeding brakes - please help
viper
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
I put new discs and pads on mine and now the brakes are razor sharp on the road . I get a sinking pedal at standstill that was probably there before the work ,but I wasn't looking for it so never noticed . Its just how ABS works so its ok.
If the brakes are ok on the road then everything is fine, the MOT will confirm everything
Post #327593 12th May 2015 11:29pm
Pepi,
Mine is, and always has been, the same, nothing to worry about, I've tried a few other 4.4's and they all do it.....
Thumbs Up Thumbs Up Pete
Post #327654 13th May 2015 11:43am
Pepi
Many Thanks All
Thanks to everyone for your response. Great to be able to chat about a subject that you are unsure about and get good feedback. Many thanks once again for taking the trouble folks.
Got to go now the Dogs ready Thumbs Up
and waiting in the back of the big Dog Eddie the eagle watch out 👀
Post #327847 14th May 2015 6:46am
Pepi
Beware the yank sites double check
Hi folks
I was still not happy with the brakes so I had a look through the bleeding procedure in my new workshop manual.
It was to my dismay that I found that the place where I gleaned the pre manual info from, was an American based forum. I Found out that the info found on a North American forum about the brake bleeding order was good for an American left hand drive car but wrong for my Right Hand Drive car. Trust me it makes a difference!!
Who would have thought that it would cause such a significant amount of air to be trapped on the system even though I was using an easy bleed and pushed an extra litre through the system at 36Lb.sq. in., just to make sure it was well flushed with fresh dot 4.
To help any one else reading this the order for a UK LHD is as follows.
Near side front=1
Off side front =2
Near side Rear =3
Off side rear. =4
My brakes are now spot on and giving the solid peddle pre start up and peddle travel on start up.
Feel much happier now.[/b] Eddie the eagle watch out 👀
Post #328393 18th May 2015 12:10am
Do you need to edit one of these?
"but wrong for my Right Hand Drive car"
"To help any one else reading this the order for a UK LHD is as follows. "
Because the left and right are when looking from the back of the car (always, for all makes, anywhere) it is easier:
As indicated in RAVE
For RHD
1. FRONT LEFT
2. FRONT RIGHT
3. REAR LEFT
4. REAR RIGHT
For LHD
1. FRONT RIGHT
2. FRONT LEFT
3. REAR RIGHT
4. REAR LEFT
Thumbs Up .
Post #328396 18th May 2015 12:43am
Pepi
Near side on a RHD car is the left as you look forward
Sorry I thought that is what I was saying!
But just to be sure.
Near side on a RHD cars is the left as you look forward Over the bonnets in the UK. Eddie the eagle watch out 👀
Post #328563 19th May 2015 8:40am
