Home > Technical (L322) > Gearbox Wont Change Up
Nickandtacita
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Thanks for the reply, its going in Monday, i will make sure these pipes are changed.
Its still getting up to 140 degrees, new larger cooler fitted to the back of the Radiator.
Post #153085 24th Nov 2012 9:47am
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
I'm sure you will get it sorted. Only trouble is possibly having to drain the gearbox oil to remove the 2 pipes that carry thr oil to the oil cooler to check them. I don't have my rave to hand , but think there are 2 hoses to the oil cooler which come off the ends of 2 metal pipes which come from the gearbox . I'm sure some one on here can confirm. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #153087 24th Nov 2012 9:56am
