Home > Technical (L322) > Air compressor which one to buy?? Confused!!
oliver9627
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I have a 2004 4.4 V8 LPG. Replaced a air spring. A week later Air suspension Inactive' came back, we plugged it in to a snap on computer and we think the compressor is tired. We cleared the fault and it is working again(for now) So i plan to replace the compressor. All of the compressors I see on ebay for a 2002-2006 range rover are black and round. Well my compressor has been moved because of the gas conversion, to the driver side compartment and it looks nothing like the ones on ebay? My current compressor is a Land Rover/ WABCO one.
Mine is a bare compressor which looks more like a later type one? Is it? Do they change them when they put a gas conversion on? If I knew how to upload pics I would
Can anyone help?
Thank You Oli[/img]
Post #150135 7th Nov 2012 6:29pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
You have a PM, regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #150137 7th Nov 2012 6:32pm
klf400
your compressor has been taken out of its accoustic shell , as there isnt room for it if you have a tank in the spare wheel well , why dont you try fitting a new compressor piston seal like i did , mine was working ok but after fitting a new piston seal it only runs for a very short period of time and is quieter than before,
this has made the compressor build up air far quicker so it doesnt get overworked, over time the seal is bound to wear out so before it starts wearing the piston and cylinder wall away it makes sence to change it ,
here is a link to the one i fitted, the audi/porsche and bmw seal is the same pump as the range rover
http://www.ebay.co.uk/itm/Audi-Allroad-Air...25777296ed Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #150155 7th Nov 2012 9:08pm
They will work. Your has just had the acoustic cover removed to make it smaller to relocate. Have a look in the wiki there's some work about stripping g ind giving it some extra life. For the money you should get the kit from Meerbusch. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #150156 7th Nov 2012 9:09pm
oliver9627
Has anyone done a compressor repair kit before? Do they work? Is it worth it? If so which one to do, I see you can buy a piston seal kit for about £35 or either a complete spring, seal and filter kit for £140 approx.
When spending over £140 i feel you are half way to a brand new compressor so you may be better to have a new compressor.
Thank you
Post #150338 9th Nov 2012 9:08am
there's a compressor strip down 'how to' in our wiki.... ... - .- -.
Post #150340 9th Nov 2012 9:11am
Meerbusch
115 GBP incl. shipping is different to 140 GBP .... ??? Had buy one aftermarket compressor for 295 GBP + shipping, but there is a sensor, which opens at 10 bar??????? Wish the buyers a lot of fun at the official dealership for modifying the ECU... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #150505 9th Nov 2012 11:29pm
oliver9627
Meerbusch
So if I buy a £300 Wabco compressor, once fitted do I need to modify the ECU? Wont it just plug in and work?
Post #150514 10th Nov 2012 8:39am
Meerbusch
The valves are only correct on the original WABCO parts at Landrover, the offers about 320GBP are good price, if they are original the same number like your original. Here in germany they cost round 600 Euro original. Ragards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #150578 10th Nov 2012 7:40pm
