Home > In Car Electronics (L322) > DVD, SATNAV system
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
I think the head unit fitted in my 2003 RR looks ugly and dated. The newer systems are much nicer but as you mentioned come at a price. I am not really that clued up on RR systems as mentioned but would be interested to learn about what is contained within the system, how it works and how it can be modified.
I was half way through starting a thread about this, I was hoping someone had a build thread or enough info for me to start one.
Post #156700 11th Dec 2012 3:58pm
mjdronfield
I like my early BMW system. I've upgraded to the Mk4 sat nav, added OEM Bluetooth phone integration, the BMW Hybrid TV tuner and had the BM54 amp unit upgraded. Much better.
Don't very often have to use the buttons around the screen, I use either voice control or the steering wheel buttons.
If you download RAVE, or have a look at the RAVE system links in the wiki, you should find a bit more out about the systems.
Failing that, there is loads of stuff on the BMW forums.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #156704 11th Dec 2012 4:06pm
SteveyD
Thanks for that, If you dont mind me asking how much did all of your updates cost you. As it stands my CD nav is faulty, tv tuner does not work (but is analogue), date cant be set, analogue clock is up the wall and stuck yet ticking quickly, radio stations and trip info work fine. Hence my thoughts about doing away with the lot.
Post #156709 11th Dec 2012 4:24pm
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
What did you need to get for Bluetooth integration??
This is the only thing extra i need for my system. i already have the mk4 satnav.
Post #156720 11th Dec 2012 4:40pm
SteveMFr
Site Sponsor
You need a BMW ULF module, bluetooth antenna, microphone and a pairing button + a quick rewire - assuming you have the phone prep loom (most do, tho).
Loads of info in this forum if you search.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #156730 11th Dec 2012 5:16pm
mjdronfield
What SteveMFr said for the bluetooth, though you can do away with the pairing button if you are happy to connect 2 wires in the boot......only needed once to pair the phone.
I got the BMW hybrid tuner for £150 off the car dealer I bought the car from who owed me a favour. Swapped my analog one to an X5 Whistle
I got the ULF, antenna and microphone from a friend of mine who was trading his BMW in. Cost me a few pints.
Did good really.
Do the mods over time, as funds come available. You can always sell on when you sell the car........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156747 11th Dec 2012 6:30pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Re: DVD, SATNAV system
I have read a number of threads on here now about needing the original unit in the glovebox for the clock / trip computer - does this maintain all functionality of the old unit without the need for this?
The original ebay link is dead, do you happen to know whether it is still available?
Many thanks in advance….
Post #241505 9th Feb 2014 9:22pm
