![]() | Home > Maintenance & Mods (L322) > Brakes! |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless Iām not at home, in which case Iām somewhere else. Posts: 6824 ![]() ![]() ![]() |
Do you mean just pads or pads and disks? Got - 2017 SDV8 Autobiography in Loire Blue
Personally think with a reasonably low ability brakes are more than possible! If you have a reasonable socket set, Allen keys, hammer, you should be more than capable. Think there are set of discs and pads on eBay! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Got mine from duckworth parts - very reasonable. Suggest sending a pm to Dan.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
Depends where you buy. Main agent quoted me £450.00 , but it can be done for £70ish DIY |
here you go :-
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Recently replaced all four sets on my L322 V8 - simple enough job as long as you have the ability to jack the car up and support it securely. The only tough bit was 'encouraging' the calliper bolts to release. Plenty of copper ease on the back of the pads and its a simple replacement job as long as you are confident and know what you are doing. There are plenty of youtube videos (Storey I think) on ow to do this.
£150+ at an Indy |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
This is a good read if you want to change you own discs / pads.
ricknayton Member Since: 07 Apr 2012 Location: Essex Posts: 29 ![]() ![]() ![]() |
Thanks a lot for all your help guys. Much appreicated.
yes, on one of the RR's and they are fine, absolutely no issues, plus saved £350ish on the stealer. I am given to understand that Mintex are OEM, but don't really care, Mintex are good anyway. |
Thanks a lot for your help Vogue. Really appreciate it.
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 ![]() ![]() ![]() |
just ordered new for mine all round and handbrake shoes from euro car parts 30% off at moment and 25000 mile warrenty |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
Gaz, is that Labour only? I've just been quoted £560 +VAT for supply and fit of front and rear brakes, discs and sensors. Also, any experience with Pagit Pads/Discs? African Bush Junkie ... in London! Stats: 2006 TD6 Vogue SE 1972-2015 DeRanged Rover 2001 P38 dHSE (SOLD) |
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 ![]() ![]() ![]() |
Pagid are oem fit for a lot of top end manufacturers so you won't go wrong with them |
