Home > Maintenance & Mods (L322) > Air filter td6
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
Air filter td6
Hi everyone, I'm about to buy this filter http://www.ebay.co.uk/itm/Range-Rover-L322...0606159749
I know how to give more information, if it is valid as a filter sport, and how often should be cleaned ...... thanks in advance!! Bow down
Post #152829 23rd Nov 2012 8:18am
i cant see the benefit of paying that much for an air filter, just get a standard one it will work just as well....
you could buy 5 of these http://www.ebay.co.uk/itm/Range-Rover-L322...ange+Rover| for what the 'green' one costs.. ... - .- -.
Post #152834 23rd Nov 2012 9:10am
madcima
is the cost is very high for what was wondering how often should be cleaned, not to change it every 10000 km ..... in terms of performance so that does not change, but if the maid service every 30000/40000 I would say it is worth worth .... Shocked
Post #152836 23rd Nov 2012 9:24am
ahebron
New Zealand
The only way to get more air through a filter of a set size is to make the holes bigger. Then you have a few issues.
Adrian VW Amarok 2014 Highline auto
Post #152855 23rd Nov 2012 10:20am
SteveMFr
Site Sponsor
I tend to regard products such as this as snake oil till proven otherwise.
If it were that easy to add HP (=increase efficiency / fuel economy as well), the OEMs would be all over it. They do not seem to be...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #152862 23rd Nov 2012 10:34am
madcima
ah but I do not seek the performance, I'm just a filter with a lower maintenance and longer life ...... Censored
Post #152909 23rd Nov 2012 1:12pm
SteveMFr
Site Sponsor
SteveMFr wrote:
If it were that easy, the OEMs would be all over it. They do not seem to be...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #152910 23rd Nov 2012 1:15pm
ebajema
I would go for the standard paper filters. To me the blurp sounds nice but I wonder the "environmental effects" are real once you do a cradle to cradle assessment.
As for change frequency, I doubt whether there will be a major/significant difference between standard and the K&N and the likes. It all depends on how much dirt goes in. If the filter holds less of that dirt the change frequency goes up but more dirt goes into the engine. I highly doubt that this filter has more area than the original filters as that is the only other factor that can affect change frequency. MY 2010 5.0 SC Galway green and sand interior!!
Post #152915 23rd Nov 2012 1:26pm
madcima
I would say then it is better to replace with an original product every 10000/20000 more that the cleaning performance of a ...
thanks I have been removed many doubts! Thumbs Up
Post #152920 23rd Nov 2012 1:35pm
The original filters are a foam type so i would say they have move area and better filtration due to the area covered by a foam surface.
every 5-10k should be the service interval for a TD vehicle regardless of what the car or manufacturer say as the oil gets nasty real quick in a TD and holds so much soot its not good for it as that forms part of the oil medium FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #152929 23rd Nov 2012 2:19pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Standard all the way with me too. Over the years tried pancake filters, K+N and have never noticed a differance...
As to filter change, I change mine yearly as for some reson the TD6 filter gets really dirty, never seen anything like it before on any other car I've owned!
Post #152941 23rd Nov 2012 3:13pm
mjdronfield
I have a K&N which was fitted a year ago. Removed the EGR at the same time, so diffucult to say what resulted in a bit more bottom end torque, but there is definately more induction noise when you accelerate........
I had a ITG air filter in my Discovery Td5 for 4 years without issue, but I do wonder when you clean and reoil the filters, if any excess oil gets deposited on the wires in the air flow meters and can cause an issue.
I shall see how dirty it is at service time, and will keep an open mind as to whether to go back to OEM or not....
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #152953 23rd Nov 2012 3:56pm
ebajema
I am running a K&N as over here the original air filters are ridiculously expensive and the environment is quite dusty. So it is much cheaper for me to run a K&H. However since I now have a good line towards the main dealer in Holland and good transport to here (I travel to Holland regularly myself amongst others), it would have been easier to go paper filters again but will stick with the K&N filter for now, to see how it holds up here. MY 2010 5.0 SC Galway green and sand interior!!
Post #152957 23rd Nov 2012 4:12pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
K&N and similar 'filters' - or more correctly 'vegetable colanders' aren't much good apart fom keeping large insects and small birds out of your engine. When it comes to protecting your engine from dust, particularly finer stuff, they just don't cut it. Go the paper filter every time. If you don't believe me, hold one up to the sun - see all the holes - they keep Censored all out...
If anyone's interested I can post up some links to some professional filter tests that show how bad some of these filters perform.
Cheers - Gav.
Post #154289 29th Nov 2012 10:22am
mjdronfield
Are the after market K&N type filters not sold on the "larger surface area" benefits of air flow ? So even if they had the same size holes as the paper elements, better air flow would still be achieved............
To be fair, I'm not convinced between K&N / ITG / Pipercross and OE etc, I just preferred the idea of not having to change it every service........
There is more induction noise, which is OK in an XR2..........OK showing my age now !!
And I still think I bu**ered up an air flow meter by over oiling my ITG, so they are far from not having downsides.....
As I said, not totally conviced at the mo. Might go back to standard. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #154295 29th Nov 2012 10:34am
