![]() | Home > Technical (L322) > Pre Heat |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
Having got my pixel issue nearly sorted yesterday, I noticed the message "Pre Heat" appear on the display this morning when I started the car.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I think it comes on under a certain temperature? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Cheers noddy,
ollielloyd Member Since: 09 Oct 2012 Location: United Kingdom Posts: 120 ![]() ![]() ![]() |
I thought this was to heat your spark plugs in very cold weather? So it's to heat the car? |
Well thats a different take on it.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
As Paul says "Pre-heat" refers to the fact the glowplugs are heating, nothing to do with FBH. |
I thought so because it goes out after few seconds. If it was preheating car it would stay on.
Just looked on a few BMW forums, and the general consensus is its the glow plugs pre heating. Some say it starts when you open the door, some say when you put the key in the ignition. Thats on later BM's though.
