![]() | Home > Technical (L322) > Battery warning light on |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
did you follow the battery dis/re connection procedure in our wiki.... ... - .- -.
L322RR Member Since: 06 Oct 2011 Location: Düsseldorf Posts: 51 ![]() ![]() ![]() |
Hi Stan,
i gather that you also did the steering fully left and then fully right, if so then check the voltage when running with a multimeter, it should be around 14.5 volts... ... - .- -.
Alternator would be my guess if batt light is on. Does the TD6 have a separate belt for it that could be slipping g if its intermittent. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Hi,
