Home > Maintenance & Mods (L322) > Alternator 240 AMP
alahmed
Saudi Arabia 2004 Range Rover HSE 4.4 V8 Bournville
Alternator 240 AMP
Hi guys
my car is RR 2004 HSE and i am facing these a battery drain issue.
i can not leave the car 3 continues days without using it , otherwise it will not start.
i took the car to a Maintenance center here specialized in BMW and RR 2003/2004 to check and solve the problem.
after checking the car the told me everything is OK except the alternator as its not working as it should be.
according to them the alternator voltage while the engine is running must be between 13.5v to 14.5v when the voltage of my car's alternator is only 12.8 maximum and because of that battery would not be fully charged.
today i have tested that by taking the car for a trip for an hour and and get the next figures
Engine Running , Voltage 12.5 to 12.8 V ( A/C+ Headlight) ON
Engine off voltage 11.9 V ( A/C+ Headlight) OFF
the other point is:
as i know the AMP of the car factory alternator is 150 AMP , so what about replacing it with 240 HIGH AMP ALTERNATOR as this one on the next link.
http://www.ebay.com/itm/251189129973?ssPag...1423.l2649
is the 240 AMP is it going to harm my car electronic devices ?
according to the item description it would not
NEW ALTERNATOR 240 HIGH AMP
OE REplacement
Use this Performance 240 Amp High Output to power all audio equipment and accessories.Or can be used as a better stock replacement
CW, 7-Groove Pulley
Used On: (2003-99) BMW 540i 4.4L
(2001-99) BMW 740i 4.4L
(2000-99) BMW 750i 5.4L
(2004-00) BMW X5 4.4L
(2003-02) BMW X5 4.6L
(2009-03) Land Rover Range Rover 4.4L
Replaces: BMW 12-31-1-705-483, -557
12-31-7-508-052, -054
Bosch 0-122-0AA-1J0, 0-122-468-015, Land Rover YLE000040
Lester Number : 13815
Part Note: 150 AMP~W... 2004 Land Rover Range Rover HSE Sport Utility 4-Door 4.4L 4398CC V8 GAS DOHC Naturally Aspirated
So please advise ASAP.
Thank you
Post #153940 27th Nov 2012 9:57pm
Your maintenance centre is correct, if you alternator only gives a peak voltage of 12.8V your battery will not fully charge, indeed you will be lucky if it achieves much more than 50% charge.
A standard replacement alternator will charge your battery satisfactorily but if for any reason you run a lot of electrical equipment on a regular basis there is no reason why you should not fit the larger output alternator.
The larger alternator will not cause any damage.
The alternator will simply vary its output relative to the load being applied to it.
Post #153950 27th Nov 2012 10:16pm
Just to put another voice to ^^^^^
Fitting the larger alternator will cause no damage and give the system space capacity. If your alternator is only putting out less than 13v then its on its way to broken.
Bear in mind if you have flattened the battery many times it
May have been damaged as car batteries do not like being deep cycled. See how it goes but bear in mind that it may need replacing as well.... There is nothing that can't be fixed with a hammer😜😜
Post #153954 27th Nov 2012 10:24pm
alahmed
So its save to replace the RR 150 AMP original alternator with this 240 AMP alternator.
Thank you so much guys
Post #154152 28th Nov 2012 7:00pm
alahmed
last update
i have installed the new 240 AM alternator.
its working perfectly.
the reading of the voltage while the engine is running is 14.0 V
Thanks
Post #158470 19th Dec 2012 12:04pm
Post #158509 19th Dec 2012 3:45pm
alahmed
Thanks nicedayforit
i am using my car on daily bases these days.
temporary i gave my other car to my brother as he needs it.
after getting my 2nd car back , i will park my range rover for 4 or five days and check if i am going to face the battery drain issue again or not.
I hope not Bow down
Post #158791 20th Dec 2012 4:27pm
