![]() | Home > Technical (L322) > STEERING FROM HELL !!! |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
When you reset stuff and disconnect the battery, you need to turn the steering from lock to lock to reset the HDC. There is a steering angle sensor that needs re-calibrated by going from lock to lock.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
looks like you've rectified all the possible causes... i can only think is , is the servotronic valve voltage correct [guess] and did you change the little filter when you put the new valve on... ... - .- -.
R4NCE Member Since: 05 Feb 2012 Location: Durham Posts: 21 ![]() ![]() |
Thanks for the fast replies.
many years ago on my morris marina the bottom bushes started seizing which resulted in very heavy steering, could this problem apply to the fullfat..
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Drive belt slipping on power steering pump? |
No sorry changed tensioner as well |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
You may want to look at the BCU unit under the passenger seat. This dictates when the servotronic steering engages. If it is faulty then the steering could be stuck in high speed mode. I had an intermittent issue where my steering was stiff at startup and normally turning the ignition off and restarting the car corrected it. I recently cleaned all the connections to the BCU and the fault seems to have been fixed. |
Hi all!
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
Have you checked out the BCU yet, as per post above ? .
hello,
James
Yeah all faults cleared many times . Disconnected the battery over night and still no difference.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I'd start by jacking up both the front wheels and having a very good look at all the steering components - ball joints. track rods, bushes etc., to see if anything is seized up.
Have you looked at the steering column itself yet ?? May be worth a look as well because it sounds like a major seizing up of the steering components to not allow the power steering to make it light. MY 2010 5.0 SC Galway green and sand interior!!
