Home > Technical (L322) > service light
robo
service light
hi am i right in saying that when ignition first switched on service indicator should light ? because nothing happens on mine just blank is there a bulb ? any ideas.thanks in advance
Post #154071 28th Nov 2012 1:32pm
Johnte
What age is it? Fill in your profile, then we'll know Thumbs Up
Post #154074 28th Nov 2012 1:44pm
robo
2004 td6 vogue
Post #154077 28th Nov 2012 2:06pm
what Jonte meant was the little car underneath your avatar...just select the appropriate one in your profile settings..
as for the service light, i cant remember seeing mine on start up.. ... - .- -.
Post #154083 28th Nov 2012 2:57pm
Are you refering to the service indicator that appears below the speedo when you turn the ignition on?
An indication of type of service required and mileage to it displays for a few seconds when the ignition is turned on.
At the best of times it is pretty faint and you have to look for it.
Not sure if the display is intended to be lit or not.
Post #154090 28th Nov 2012 3:14pm
Every time you switch on the ignition the mileage indicator changes (for a few seconds) to the amount of miles left before a service is due
Post #154094 28th Nov 2012 3:43pm
robo
Ok, thank you all
Post #154157 28th Nov 2012 7:21pm
