![]() | Home > Technical (L322) > TD6 Heating unsloved problems |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6430 ![]() ![]() |
Workshop not registering any faults with the A/C Heater system ? .
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
I had similar symptoms on my old P38 and had to replace the ECU. ----------
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
Unfo workshop can see not any fault.Wondering if was ECU wouldnot be possible to be read????? |
From a look i just had ecu is integral part in heating control panel.But wondering if any way to test it? |
Have a look online for the Workshop Manual of the L322, it is in PDF and is for the 2002 to 2005 model year like yours. Then go to the A/C/Heating section and have a look at the various valves that direct the warm/cold air flows. It could be the actuators or vacuum hoses controlling the valves that are giving you the problems.
Thanks your replies.By the time will start blow warm air all seems that are in order.i have lower/upper/face/back heating provided that i will not try reduce temp from full either from driver's or codriver's switch.So till this stage i guess that valves/etc normally work.But still i donot know if change of temp has something to do with vacuum hoses controlling the valves or valves.is this possible?To me heating system seems to be very complexed with too many stuff and unfo i understand very few thinks. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8784 ![]() ![]() ![]() |
AFAIK the dual zone is controlled by two solenoid valves in the engine bay, one for left and one for right hand side. maybe these have become faulty? they are between the inner wing and the engine on the right hand side as you look into the engine bay, they open to let warm water into the heater matricees inside the car. There is nothing that can't be fixed with a hammer😜😜
