![]() | Home > Technical (L322) > head light fuse help |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
Does anyone know where the passenger side dipped haedlight fuse is and the fuse number ?? |
ive got dipped headlight out and was looking for a fuse but it has been flickering for over a year |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
I assume you have checked the bulb? |
hid and yes i swapped it |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35790 ![]() ![]() |
ballast? ... - .- -.
im tinking the same has anyone purchased one from ebay ??? |
Before going for a ballast it might be worth checking to see if you have 12V at the headlight. |
ok will check |
You could also change the ballast from the other headlight to double check. |
