Home > Technical (L322) > front parking sensors
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
hi All, my front sensors have suddenly stopped working. Question Big Cry the rears are fine and all was well with the front ones, then just got in the car and they were no longer working. any ideas as to what i could check and what is the easiest way of getting at them? do i actually need to remove the bumper Rolling Eyes Rolling Eyes Rolling Eyes
bob
Post #157691 15th Dec 2012 11:48pm
Is it icy there? I have seen mine stop working in heavy frost or ice. Previously..
Post #157693 15th Dec 2012 11:55pm
Johnte
Have a look here -
Post #157699 16th Dec 2012 12:14am
GJOB
2005 Range Rover Vogue SE Td6 Java Black
It's easy to diagnose:
1. Once you have activated the front PDC - put your ear up to each sensor and listen for a clicking sound.
2. If none of them are clicking then it is likely to be a break in the wiring loom
3. If some are clicking then the chances are it is a single sensor failure
I replaced one a couple of weeks ago and couldn't find anything useful on YouTube to explain how to remove the front bumper so I used the workshop manual (which isn't brilliant but you can work it out). It can be done in 10 minutes once you know how Thumbs Up - remove grille, remove about a dozen screws and don't forget the 2 hidden ones behind the plastic caps, remove the screw in each wheel well of off she pops. Be careful the wiring isn't very long so you'll need something to rest the bumper on Exclamation
Post #157724 16th Dec 2012 10:27am
wanderer
2012 Range Rover Westminster 4.4 V8 Orkney Grey
A dealer is currently replacing one of mine and said that the replacement will need spraying up in body colour. Is that correct, do replacement sensors need spraying?
Post #157738 16th Dec 2012 11:15am
If you want them to match. Don't think you can get replacement sensors in "all" colours. If you need to know for sure check with Duckworths Dan. .
Post #157757 16th Dec 2012 12:16pm
wanderer
Thanks Joe. Just being overly suspicious.
Post #157782 16th Dec 2012 1:39pm
BOBCUSSEN
hi archie, no it is not really icy. infact very mild at around 16 degrees at the mo. i will listen at the front and see if i can hear anything clicking? with regard to switching them on, i assume i just turn on the ignition and put it in drive to test them Question would that work
bob
Post #157895 16th Dec 2012 8:28pm
Leave it in park. There is a button, bottom left, to switch on the park sensors. Thumbs Up Previously..
Post #157897 16th Dec 2012 8:31pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
When I lost the front sensors, it was the PDC ECU in the boot that needed to be replaced.
Post #157901 16th Dec 2012 8:42pm
BOBCUSSEN
ok mate, i did know about the button but just thought that used if you wanted to keep them on whilst driving Question Question . the rears are working no problem; so dont know if that rules out the ecu in the boot Question unless there are seperate ones for front and rear Question Question
bob
Post #157904 16th Dec 2012 8:45pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
bob
On mine (2007MY) that will not activate the fronts, reverse has to be selected or switch pressed before system is switched on
Post #157917 16th Dec 2012 9:47pm
BOBCUSSEN
Question well when i get in mine, i normally just start it, and if i put it in reverse, it works straight away, and if i pull forward it also works straight away Question . i dont have to switch anything on for it to do this Question; the light comes on on the switch without me having to press anything. i thought if you wanted to have them on whilst driving, you just needed to press the switch, and this would alert you when approching someone or something, and vice versa.?
however i am a newbie to this wonderfull motorcars, so hell, what do i know. Very Happy Embarassed Very Happy
so please correct me if again i have it completly wrong Rolling with laughter Rolling with laughter Rolling with laughter Bow down
bob
Post #157918 16th Dec 2012 9:55pm
Katash
To get to drive you transition through (assuming you leave in park) reverse, think this is what triggers the system.
My routine is start engine, select reverse and back out - during this time both front and rear are active - drive off and exceed the trigger speed and the system is deactivated. when coming home I have to manually turn the system on or select reverse (if system has been turned off manually reverse will not activate system until a power cycle)
Post #157929 16th Dec 2012 10:24pm
BOBCUSSEN
yes, when i start, i jus put in reverse and on comes the light and the rears are working, when i pull forward, up until they stopped, the fronts came on without having to do anything else. when i start driving, after a short while the light goes off. i guess i will just do the checks as i expect it is either the sensors themselves or the rear ecu
Post #157944 16th Dec 2012 11:28pm
