Home > Technical (L322) > wouldnt go in gear and hello Forum
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Hi forum,
This is my first post on here so go easy on me please... Big Cry
This morning after dropping my son off at nursery I pulled away fine then suddenly my 04 l322 v8 went into no gear and said select Neutral on the dash screen, I followed this I selected Neutral switched the car off then back on then tried to put it into drive but it wouldn't have it!
As I was blocking the rd leading up to the nursery I had to get another dad dropping his son off to use his 4x4 to push my car backwards whilst running n Neutral, once he had done this I again switched off my car then back on and all was well. So what was that all about ? My concern is that the car slipped out of gear if that were to happen on a busy junction I hate to think what would be the result.
Any Ideas as to why my car did this it seems to be running a bit slow on gear changes now and some times I am even getting up to high revs before she will change gear ... any advise ..
Post #11316 20th Jan 2010 1:52pm
JMC
Flush the gearbox and replace the oil would be my initial thoughts. Confused
Welcome to the forum Thumbs Up The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #11317 20th Jan 2010 2:03pm
kb5
Do you think this would resolve the issue as I am wondering could it be a torque converter problem I would prefer for it to be just a flush and oil change as I am sure that would be the cheaper fix...
Post #11325 20th Jan 2010 4:54pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
I'm not sure what I have is any way related to your problem...
Stiff selector; progressively getting worse over the winter months. My car would occasionally jump out of gear (selector shows D), but dash display shows nothing. If I hold the selector in D by pulling back, the car is fine, and dash shows D. I figured there was an issue with the linkage. Ignoring this, I just drove the car around in sport mode over the last month with no issues... until last night. I had a Transmission Fail warning come up on the display, and lost the use of sport mode and manual gear selection. I was able to drive home with the car in D, by holding the selector in D. All shifts seamless as expected. Release pressure from gear lever, and the car would pop out of gear (when moving), or when stationery, not popping out of gear, but loss of drive and the D on the dash display.
I found a technical bulletin regarding the problems for the ZF gearbox, and my symptoms are a classic case of a seized linkage cable and mis-match of sensors as a result of this - an easy fix.
http://www.disco3.co.uk/gallery/albums/use...0guide.pdf
P.S. to check if it is this, when you are in drive, just put a bit of forward pressure on your selector (not much though), and see if your dash D display goes out. Ambient temperatures and moisure levels make a difference to this too I have found.
There are a lot of different fault/fixes in the guide; so if you do not have the same problem as me, you may be able to identify it being something else within that guide.
HTH Smile
Post #11499 23rd Jan 2010 4:42pm
kb5
Quote edited out by Mod: Cool
Many thanks for this I shall go through it and hope it shows me what the fix is to my problem as I dont want to end up shelling out for a new box... Sad
Post #11534 24th Jan 2010 7:30am
jayzee
Good luck, and hope it is a trivial and inexpensive fix for you.
Maybe the link should be a sticky?
Post #11545 24th Jan 2010 11:57am
These may help when talking to a dealer?
High Engine Speeds and/or Transmission Shift Problems To subscribe to view this document click here
Reference: LTB00080 (1) Folder: Cooling System
Range Rover - Gear Selection Difficult/Stiff To subscribe to view this document click here
Reference: LM307-004 (1) Folder: Gearbox Discovery 4 HSE
1993 90 Tdi
Post #11550 24th Jan 2010 12:23pm
kb5
Oh if only there were a dealer in this country .... Bow down
Update on post
today again my car would not go into gear after I had just driven it. After trying to get it back into gear I returned it back to P there was a kind of grinding clicking noise (sounded similar to putting something on a fan blade). I switched the car off on etc but this was no help, the low range light on dash came on I put the gear shift in N and tried to change range mode but couldn't. I finally got a couple of people to push the car forward which for some unknown reason sorted out the getting it into drive but the low range light stayed on.
Post #11598 25th Jan 2010 7:47am
Does it make any difference if you select Neutral and switch it between Low and High range a few times? Discovery 4 HSE
1993 90 Tdi
Post #11604 25th Jan 2010 10:23am
kb5
No selected N a few times and tried to get it out of low range but it wouldn't It also wouldn't go into gear and as I said when I put it into P it made this noise of plastic on fan blades?
any thoughts ?
Post #11608 25th Jan 2010 10:51am
I'm out of ideas I'm afraid, your best bet may be to call a specialist or a dealer service dept. Have you got any numbers/ a copy of LRO for example? Discovery 4 HSE
1993 90 Tdi
Post #11620 25th Jan 2010 2:28pm
kb5
I am sure I'll find some thanks for the advise.. So far ...
Post #11623 25th Jan 2010 3:15pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
on the td6 trans if the oil is low in the transfer box the high/ low range wont work as it relies on oil to make the pump select high or low if no oil it stays in neutral in yhe transfer box , get down the dealer get a litre of transfer oil and top it up its blind folded hand tied behind your back easy Thumbs Up
*could someone attach a pic from rave or anywhere of the transferbox fill and drain plugs arrowed *
Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #11630 25th Jan 2010 6:51pm
ZF Auto Drain plug from Rave Workshop Manual:
And the refill plug:
 Discovery 4 HSE
1993 90 Tdi
Post #11634 25th Jan 2010 7:10pm
speedymarktd6
i believe thats the main gearbox would you be able to post pics of the transferbox Thumbs Up onto no6 Range Rover
Post #11636 25th Jan 2010 7:13pm
