Home > Off Topic > The laws of physics in cartoons
mzplcg
Cartoon Law I
Any body suspended in space will remain in space until made aware of its situation.
Daffy Duck steps off a cliff, expecting further pastureland. He loiters in midair, soliloquizing flippantly, until he chances to look down. At this point, the familiar principle of 32 feet per second per second takes over.
Cartoon Law II
Any body in motion will tend to remain in motion until solid matter intervenes suddenly. Whether shot from a cannon or in hot pursuit on foot, cartoon characters are so absolute in their momentum that only a telephone pole or an outsize boulder retards their forward motion absolutely. Sir Isaac Newton called this sudden termination of motion the stooge's surcease.
Cartoon Law III
Any body passing through solid matter will leave a perforation conforming to its perimeter.
Also called the silhouette of passage, this phenomenon is the speciality of victims of directed-pressure explosions and of reckless cowards who are so eager to escape that they exit directly through the wall of a house, leaving a cookie-cutout-perfect hole. The threat of skunks or matrimony often catalyses this reaction.
Cartoon Law IV
The time required for an object to fall twenty stories is greater than or equal to the time it takes for whoever knocked it off the ledge to spiral down twenty flights to attempt to capture it unbroken. Such an object is inevitably priceless, the attempt to capture it inevitably unsuccessful.
Cartoon Law V
All principles of gravity are negated by fear.
Psychic forces are sufficient in most bodies for a shock to propel them directly away from the earth's surface. A spooky noise or an adversary's signature sound will induce motion upward, usually to the cradle of a chandelier, a treetop, or the crest of a flagpole. The feet of a character who is running or the wheels of a speeding auto need never touch the ground, especially when in flight.
Cartoon Law VI
As speed increases, objects can be in several places at once.
This is particularly true of tooth-and-claw fights, in which a character's head may be glimpsed emerging from the cloud of altercation at several places simultaneously. This effect is common as well among bodies that are spinning or being throttled. A `wacky' character has the option of self-replication only at manic high speeds and may ricochet off walls to achieve the velocity required.
Cartoon Law VII
Certain bodies can pass through solid walls painted to resemble tunnel entrances; others cannot.
This trompe l'oeil inconsistency has baffled generations, but at least it is known that whoever paints an entrance on a wall's surface to trick an opponent will be unable to pursue him into this theoretical space. The painter is flattened against the wall when he attempts to follow into the painting. This is ultimately a problem of art, not of science.
Cartoon Law VIII
Any violent rearrangement of feline matter is impermanent.
Cartoon cats possess even more deaths than the traditional nine lives might comfortably afford. They can be decimated, spliced, splayed, accordion-pleated, spindled, or disassembled, but they cannot be destroyed. After a few moments of blinking self pity, they reinflate, elongate, snap back, or solidify.
Corollary: A cat will assume the shape of its container.
Cartoon Law IX
Everything falls faster than an anvil.
Post #159022 21st Dec 2012 2:57pm
Cartoon Law X
if you're noticing all this then you're watching to many cartoons... Laughing ... - .- -.
Post #159029 21st Dec 2012 3:12pm
Cheers for that Dom , will sleep better tonight knowing all that …. Laughing Laughing
Post #159036 21st Dec 2012 3:22pm
mzplcg
Always aim to please Mick. Thumbs Up
Post #159042 21st Dec 2012 3:29pm
A1GSS
Rolling with laughter Rolling with laughter
Very good.
What about Cartoon Law X
Faces hit with an object assume the shape of the object.
A cat hit with an iron becomes iron-shaped. The face of a dog hit with a frying pan becomes pan shaped. Etc Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #159043 21st Dec 2012 3:33pm
