Home > General > Keep calm and drive on ....... if you're in a rangie!
Page 2 of 3 <123>
Flashman
Just be careful you don't drive over an open manhole. Tom
Current Drive
Previous Drives
Post #159485 23rd Dec 2012 11:32am
The ff can cope with that if your but blitzing along and have some good offroad tyres Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159489 23rd Dec 2012 11:45am
Andy
Unless I knew that road extremely well, I would not be driving through that flood. No-one knows what's underneath.
Post #159751 24th Dec 2012 8:50am
Very true noddy. As has been shown on the disco forum where a members daughter and grand kids were in a Zafira and went through a ford and the engine cut out when the water got upto the windscreen and the water level was near the door tops....
Luckily the engine survived after taking on a load of water after they sucked every drop out of the chambers and pipes and it fired up OK other than some water in the oil so they are draining that today.. Very lucky escape TBH as it could have been so much worse if the water had been moving at any speed... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159767 24th Dec 2012 10:28am
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
goes without saying about familiarity.maybe they knew it very well
Post #159772 24th Dec 2012 10:43am
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
One question for you guys, what stops the water coming in the doors in a situation like this? I can see a quick jaunt across a ford not being too much of a problem but that RR is going to be in deep water a fair while. I remeber a few years back in Spain my mate had a brand new Defender, we had already modified it quite a bit with a lift and 'proper'tires, snorkel etc, we stopped somewhere and after a while someone is like 'where's Frank?' we spotted him crossing a river and the water was up to the door tops, he got acrossOK but the interior was soaked, luckily it dried Ok and we had it valeted, but a defender is far more suited to getting wet than a FFRR. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159822 24th Dec 2012 2:45pm
much better seals than a defender, but they will leak a bit inevitably. Did some deep wading a couple of weeks ago, didnt let any water in over a 500 yard swim. There is nothing that can't be fixed with a hammer😜😜
Post #159828 24th Dec 2012 3:02pm
JohnnyDangerous
Its just that they seem to have so many electrical problems that introducing a good dunking terrifies me, I dont mind going out in snow etc, in fact we actually use the country roads to find more snow but wading oh no !!!!!! Embarassed One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159830 24th Dec 2012 3:05pm
The problem with dunking an l322 would be the air intake at the rear of the bonnet. There isn't anyway to close it off so the water would run down it and into the interior.
I've had water upto bonnet level during a river crossing and the car didn't have a drop in it compared to a rasied 300tdi in front of me which was sopping inside!
Double door seals help a lot and if you had an armoured edition you could go in full depth of the air intake without issue and even if the engine did cut out taking water in the occupants would still be dry. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159837 24th Dec 2012 3:15pm
JohnnyDangerous
A couple of my seals have small tears in them, maybe Ill change em just in case I have to drive thru a ford and soak any Merceded drivers Twisted Evil One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159842 24th Dec 2012 3:22pm
I have a nick in my drivers side one that's about an inch long if that but i think its more important that it makes a seal. I tend to clean mine every wash and gently wipe them to ensure no dirt gets in as that's the killer really as it acts as sandpaper over time and makes them brittle. I also bought some of that rubber car blobby stuff that others on here have recommended and being a short a53 isn't easy to apply to the top of the rubbers on the door frames but have now done the whole car and will do it again after it gets a proper clean in the next few days, probably tonight so its done for the xmas runs Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159850 24th Dec 2012 4:07pm
JohnnyDangerous
Having had many jap cars with targa tops a quick fix for a slight leak is to coat the seals with a silicone type product similar to vaseline, just seems to add that extra seal to it. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159852 24th Dec 2012 4:11pm
ahebron
New Zealand
One of the issues with using a grease is that dirt and grit stick to it making a grinding paste.
Adrian VW Amarok 2014 Highline auto
Post #159962 24th Dec 2012 11:15pm
JohnnyDangerous
Yeah on a door seal you would need to clean it quite regularly i would think, on the roof it was shut and forget till spring. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159964 24th Dec 2012 11:26pm
The issue with the bonnet vent is possibly the reason there is no snorkel available. Whistle
From memory in the manual, I think that the wading depth is 500mm for the tdv8, that is quite deep in reality, though it will do a fair chunk more, i reckon that 7-900 mm is feasible with no issues.
To put that in perspective the maual off our hilux, wading.... Nooooo! There is nothing that can't be fixed with a hammer😜😜
Post #159966 24th Dec 2012 11:32pm
Page 2 of 3 <123>
