![]() | Home > Technical (L322) > Wont start |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Are you sure it was a fault that was showing, and not just a signal to say that the shift was not fully in PARK?? I know you know now, but usually moving the shifter back and forward will get it to start. |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Probably just the stick not fully in park - common thing, happend to me twice - both times while I was in a rush while parking up. Just moved stick out of and then back into park and works fine. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Sounds like the car didn't think you were in Park enough to allow starting. This could be due to a couple of things. The inhibitor switch, which lives on top of the gearbox behind the engine, may be the root of your problem, or you could be having problem with your selector cable/s (one that runs from gearstick to ignition, and one that runs from gearstick to gearbox). The latter can get bent or seize up at the linkage.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
Have you ever greased the selector cable on the car?
honeyman Member Since: 28 Dec 2012 Location: Bristol Posts: 21 ![]() ![]() ![]() |
Many thanks to all for your suggestions that I will try, will now try car and see and let you know . |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Is it cranking but not starting? If so, have you checked the fuel pump underneath in front of NSR wheel?
Hi Richcl No it is not cranking but just a clicking from the immobilisation module
Have you greased the selector cable and crank arm on the side of the gearbox? |
Sorry, inhibitor switch on the GM 5L40E (TD6) box is inside the gearbox itself, the inhibitor switch for the ZF 5HP24 is on top of the gearbox (below the plenum chamber).
To all the members of this forum who replied to my battery problem on my RR 2006 TDi For a number of years (2) i suffered starting problems, so getting fed up with it I ordered from Amazon a combined amp/volt meter and a current shunt with all this ready to go I had one journey to make which to me close to the place I purchased my battery so I popped in and explained my problem, their suggestion was to replace the battery and send the old one for testing..... AND GUESS WHAT !!!!! they contacted me to inform me that the battery was faulty and would be replaced without charge. SO I've had it month with no trouble starting. So I never did get to do my test.... |
I own a 2006 Range Rover Vogue 3.0 L322 Diesel which I purchased from new and now with 33,000 miles the only problem I’ve had is the battery that has failed twice I have decided to keep it for a few more years. This model has a TV fitted but does not work due to being analogue. Does any member know how and where to purchase a digital replacement. I live in Bristol England UK |
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 ![]() ![]() ![]() |
There is a member on here called Baris IIRC, his business is called Carphonics and is in Enfield.
