![]() | Home > Technical (L322) > brakes binding on all corners? |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
You might have the bite the bullet and change all 4 calipers. A common problem on the FFRR but the calipers are not too expensive |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
Bit the bullit. Not TOO horiffic price (best price i could find) |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
The outer edge of the piston will rust over time when there is little left on the pads. This may affect the retraction negatively when new (and thicker) pads are mounted. ----------
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8784 ![]() ![]() ![]() |
I am just in the process of having the NSR caliper replaced at MD exactly the same symptoms, the outside pad had worn out and the other 3 on the rear were fine. The other side has has the seal slightly damaged at some point or other in the past, but it's working fine at the moment. I think I would be pushing my luck to get this changed as it is still working properly. There is nothing that can't be fixed with a hammer😜😜
Mmmm - all four at once? Seems highly implausible to me. 2 at once... okay if the car sat for a bit. 4? |
I agree steve. The only thing is i have changed the pads, so pushed the pistons back in. I can understand the o/s/r as i thought that was binding and wanted to see if cleaning it up and new pads would help, but the fronts seemed fine. |
