Home > Technical (L322) > Td6 power steering
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Td6 power steering
Hi,
I currently have a noisy power steering pump, it is whining and almost grinding on heavy turns. Before I replace the pump I want to try and flush the fluid. The only problem is I can't find the exact fluid spec. I don't know if I'm just being blind but I can't find it in the rave or on google, and I don't have a manual. I have heard rumours that it is the same as gearbox but I want to be absolutely sure.
Any help is greatly appreciated.
Kind regards, Luke.
Post #165519 17th Jan 2013 9:49pm
ahebron
New Zealand
I had a look at the Penrite oil site and it gives the following for the TD6
http://www.datateck.com.au/Lube/PenriteAus/
Power Steering & Suspension Fluids
PAS FLUID (POWER ASSISTED STEERING)
Semi-synthetic fluid designed for use in Land Rover ACE and power steering systems. Also suitable for use in power steering systems that require automatic transmission fluids and in all Chrysler/Jeep power steering systems and US built GM/Holden/GMC. Can be used as a 7.5W motorcycle fork oil.
Key Specifications:
Land Rover PAS 14315, Chrysler MS 5931/MS9462, MB 236.3, MB 341, Ford M2C195A, GM 9985010
Hope this helps
Adrian VW Amarok 2014 Highline auto
Post #165526 17th Jan 2013 10:04pm
STC50519
Post #165529 17th Jan 2013 10:26pm
Also try site sponsor Opie Oils. They have a very good "oil finder" app on their site. .
Post #165546 17th Jan 2013 11:38pm
barracuda816
Thanks for the quick reply guys.
Does anyone know how much the system takes (or how much to flush it)
Lastly, has anyone had a similar issue?
Kind regards, Luke
Post #165669 18th Jan 2013 1:53pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
had it about 4 years ago. just went to the dealer and asked for power steering flued. refilled it _ the fill cap has a measure stick built in- and never had any problems after
Post #166275 21st Jan 2013 2:47pm
