Home > Off Topic > sky hd box experts
sky hd box experts
just put a 2.1 soundbar up in my sons bedroom and connected to the sky hd box via optical cable, but i only get sound from the soundbar when sky box audio is set to 'normal' and nothing on 'dolbyd'...any ideas? ... - .- -.
Post #165600 18th Jan 2013 10:40am
Does the sound bar truly support Dolby d?? I think I've read of issues like this Before on the av forums.
Have you had a nose on google incase the sound bar needs a fidling with?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #165619 18th Jan 2013 11:18am
sky outputs 5.1 but thats all the range up to 5.1 including 2.1 apparently ..soundbar defo takes 2.1..i have googled Will but found nothing... ... - .- -.
Post #165624 18th Jan 2013 11:29am
JAYBOY
Wales 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
Is there a mode button on the sound bar. Question
You will need to have 2 HDMI Leads for it to work
HDMI from your sky through the sound bar to the tv
press the mode and switch it to AUX it should work through all chanels then.
I had to do the same with mine Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2017 Range Rover Autobiography 5.0 V8
2018 JCW Mini Cooper
2018 Skoda VRS
Post #165627 18th Jan 2013 11:32am
Jayboy, sky hd won't output anything more than stereo Over hdmi Wink
I can't put my finger on it stan but it sounds familiar.. Have you tried joinin and searching the av forums?
Sorry I can't be much more help but the net here is 0.1meg when it works and being away from home makes it that much harder ;( FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #165634 18th Jan 2013 11:37am
@Will, searched the av forums but cant find anything similar...
@Jayboy, soundbar is set to optical and only one connection which is the optical cable [toshlink].. ... - .- -.
Post #165638 18th Jan 2013 11:43am
