Home > In Car Electronics (L322) > installing Bluetooth, need help
Page 1 of 3 123>
djharm
Netherlands 2002 Range Rover Vogue SE Td6 Java Black
guy's, I've been installing Bluetooth in my td62003, car is pre-wired and I bought a gen3 module.
got a new 54pin plug at Audi and rewired everything due to the pdf flying around here on the forum.
Telephone shows up at the Nav. screen but asked for activation, So i dove in to this forum again and found out I had to ground pin 32 to pin 36. Did that, and....... nothing changed.... there is a Bluetooth Nokia module installed by a previous owner, so i was searching if they disconnected something, but didn't find anything...
what I did find was that the antenna from the module goes .....nowhere... Am I missing a part? like a Bluetooth antenna or something? thanks
Post #167308 24th Jan 2013 9:52pm
djharm
Am I missing an aerial?
Post #167321 24th Jan 2013 10:17pm
mjdronfield
As PM.....
Hi mate,
Can't help much tonight as I'm out again in a min........
If its saying you need to activate phone, you will need to put the ULF into pairing mode by following the pairing procedure........
To get the ULF in pairing mode, with ignition off, short the wires together for at least 1 second before turning ignition on, and continue to short them for 2 to 3 seconds after ignition switch on. Whilst ignition still on, seperate the wires. All 3 LED's should be lit on the screen display in the car and some instructions will appear on the car screen. Do a bluetooth search with your phone, and pair up entering the ulf passcode when required.
You should have bought a bluetooth antenna as well as the audi plug and your ULF. Your car should already have the cable in.
Not sure of BMW part number........
see how you go....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #167322 24th Jan 2013 10:22pm
mjdronfield
Something like this ;
http://www.ebay.co.uk/itm/BMW-Bluetooth-an...337f6da833
You should already have 2 bolts sticking up from the black frame above your sat nav unit in the boot........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #167326 24th Jan 2013 10:25pm
djharm
Ok, first thing tomorrow, of to the BMW stealership. They will probably not have it in stock. But thanks for the feedback so far guy's. Thumbs Up
Post #167371 25th Jan 2013 1:21am
djharm
part ordered, it will be in on monday.
Post #167485 25th Jan 2013 3:19pm
mjdronfield
When you ground pin 32 to 36, you are leaving pin 36 still connected to the ULF ?
......as its the ground for the ULF unit. I used a choccy block, and just touched the wire from pin 32 into it as required.
Just a thought.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #167542 25th Jan 2013 7:02pm
djharm
I'm keeping 32 and 36 both in the ULF, didn't try to activate it since I have to wait for the aerial to arrive, so I can do it all at once.
Or do I have to take 32 out while grounding it to 36? And put it back after?
Post #167678 26th Jan 2013 2:24am
mjdronfield
Pin 32 only goes to the ulf, so leave connected. The other end I put a choccy block on so it doesn't touch stuff when it's not being shorted for pairing.
To clarify what I said in my pm and first reply above, currently your ulf is trying to connect to the mobile phone of its last owner. So you need to pair yours using the pairing procedure. This will only have to be done once. Afterwards when you see the activate phone message, you'll just have to do just that - turn on your phone or activate its bluetooth.
My car displays that message when I leave my mobile in the house........and try and make a call from the car when I'm miles away! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #167691 26th Jan 2013 9:34am
djharm
Ok, ulf is working and pairing with my phone, only thing left to do is installing the mic. I do see the plug but that doesn't mean i can reach it... so I will have to tear down some stuff... I'll report back in a couple off hours...
Post #168202 28th Jan 2013 8:46pm
mjdronfield
The black cover should just pop out from your car, so you can just connect the mic up and clip it back in.........
Hopefully thats all the removal you'll have to do.
Sounds good so far.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #168257 28th Jan 2013 10:09pm
djharm
not quite, I could see the plug but it was tied together in a bundle, just out of reach. But I got it, and all is working, so thanks for helping out.
Of to the next project, witch will be sending the bm54 off to Baris..
Post #168276 28th Jan 2013 10:42pm
mjdronfield
Excellent.
Baris upgraded my bm54.......... well worth it...........
let me know what you think.......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #168282 28th Jan 2013 10:58pm
djharm
Not quite sure what to choose, the iPod cable or streaming Bluetooth. besides the amp upgrade and firmware
Post #168284 28th Jan 2013 11:08pm
djharm
hmmm.... somehow the ULF only remembers the calls from the former user, everytime i get in the car my calls are gone and the old ones pop up.. anyone have an answer to that?
Post #170015 4th Feb 2013 4:33pm
Page 1 of 3 123>
