Home > General (L405) > Weight
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Weight
Sport SE V6 diesel= 2535kg
2013 Range Rover V6 diesel = 2160kg
2013 Range Rover V8 diesel = 2360kg
I never realised how much weight saving the new models had.
Post #168433 29th Jan 2013 3:14pm
Philip
Never found any confirmation, but it seems they might quote Italian-style dry weights because the tested weights are always higher (both L322 and L405). Autocar's test SDV8 weighed 2625 kg against 2360 kg quoted (although I believe they test with two people and a tank of fuel); NCAP TDV6 2313 kg vs 2160 kg quoted.
Post #168439 29th Jan 2013 3:27pm
oldcro
All weights were taken off the Landrover web pages so would expect them to be representive of the improvements made.
Of course actual weights could be higher depending on specs and fluid levels etc.
Post #168502 29th Jan 2013 7:24pm
aneurysm1
2010 Range Rover Autobiography TDV8 Cairns Blue
They have publicised that the new model is around 400kg lighter. Hence improved fuel consumption that all manufacturers have to follow these days etc
Post #168519 29th Jan 2013 8:19pm
RR2008HSE
Yes, lighter than the L322, but still significantly heavier than the original Range Rover.
Post #168703 30th Jan 2013 4:21am
The sport is heavier than the 322 so the 405 must be lighter than both... Simples... Wink
Post #168734 30th Jan 2013 9:58am
oldcro
Is it?
Post #168804 30th Jan 2013 3:20pm
campaj1
it would make sense... RR monocoque, sport uses that heavy dual chassis thing from the disco x
Post #169355 1st Feb 2013 4:53pm
oldcro
Strange comments about the L322 being lighter than the Sport as a 2010 L322 diesel is quoted as being 2710kg, making the L322 175kg heavier.
All weights taken from TOPix handbooks.
Post #169393 1st Feb 2013 8:28pm
oldcro
Double post again. Big Cry
Post #169394 1st Feb 2013 8:28pm
campaj1
Think it was model dependant: some of the late tdv8s were getting on the porky side, but I read that weights ranged from 2415-2710 x
Post #170051 4th Feb 2013 6:53pm
