Home > In Car Electronics (L322) > Looking to buy Intravee, but where does it sit?
dirtyharry
I've searched as many posts as I can on this, but I can't seem to find the answer. Embarassed
I'm looking to buy the Intravee/Alpine 420i kit to enable Ipod connection in my 2004 Vogue and am happy to do away with my CD changer, but can someone tell me where the two replacement units go? Will they fit in the space left by removing the CD changer? Or are they too big to fit in there? Do they fit behind the footwell? Confused
I recently had the whole glovebox and CD changer out (what a friggin' nightmare that was!!) as a CD had got stuck and I managed to fix it, but I did take the step of NOT fitting all the screws back into the CD housing, so it now slides forward without me having to dis-assemble the glovebox again Wink I know I have the 3 and 6 pin connections on the CD changer, not the 10 pin, so I believe this will make installation of the Intravee a lot easier.
However, I still have a feeling someone is going to tell me either the Intravee or the Alpine (or both for that matter!) will have to sit behind one of the dashboard/footwell panels, or even worse, in the boot Sad Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #168718 30th Jan 2013 9:01am
Good news Greg... They fit along side the changer, or in place of the changer as there is plenty of room Thumbs Up
Post #168722 30th Jan 2013 9:29am
dirtyharry
That is exactly the answer I was hoping for! Thanks chap Very Happy Cheers
Greg
Previous vehicles:-
Post #168723 30th Jan 2013 9:31am
No worries Thumbs Up Enjoy Thumbs Up
Post #168727 30th Jan 2013 9:36am
If you need an Intravee and the 420i, I have a very lightly used set available if you're interested that was only in my FF for around 8 months. Si. <This is my name.
Post #168742 30th Jan 2013 10:39am
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
They are actually small enough and have enough cable you do not need to fit in the glovebox at all, you could put them in the centre or behind the side pods and run the lead for Ipod to the top armrest cubby, if you do this you more than double the size of the glovebox but dont forget to run a lead from the serial port to where you can reach it easily for firmware updates, then have fun setting the mirror folding, auto lock and PDC distance readout, its worth it for those alone IMO.
The intravee itself is the size of a pack of cigs !!! One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #168745 30th Jan 2013 10:45am
dirtyharry
Does a lot more than just play an Ipod then! Very Happy
Thanks for that info. It would be useful to free up the space where the CD changer is, and fitting them behind the side pods is so much easier than faffing around with the glovebox! Thumbs Up Cheers
Greg
Previous vehicles:-
Post #168784 30th Jan 2013 1:18pm
dirtyharry
Hi Bellini
PM sent (or at least I've tried sending one but noticed it's still in my outbox!). Though I'm sure you know what I'm asking Wink Cheers
Greg
Previous vehicles:-
Post #168785 30th Jan 2013 1:24pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Also as Johnny knows u need the latest firmware to get the extras on the intravee
I have mine mounted in the side panel section of the dash so its easy to get to, i also have the ALpine 6 disc mp3 changer in my set up
Post #168787 30th Jan 2013 1:37pm
dirtyharry
Is it just a case of connecting the unit to a pc and downloading the latest version? Or not as simple as that?! Cheers
Greg
Previous vehicles:-
Post #168791 30th Jan 2013 1:50pm
JohnnyDangerous
Do not use it unless the firmware is updated ehhh Cliffy, when its all updated and working you will be amazed at what it can do, one little tip, you have to go in the memory and set it up for which vehicle its in, I ended up telling it thats its in a BMW X5 and all is now good, there is full support on the BM forum, i have the addy if you get stuck. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #168846 30th Jan 2013 5:50pm
JohnnyDangerous
Yes if your pc literate, im not !!!!!! Big Cry Cliffy did mine. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #168847 30th Jan 2013 5:51pm
cliffy
And to get the extra menu in it u have to agree to the t&c's of the software whilst connected to ur car
Post #168852 30th Jan 2013 6:03pm
cliffy
ive got the latest firnware and pdfs for install if u need them, u will also need a COM port connection, if not ur need a usb to com connector
Post #168853 30th Jan 2013 6:08pm
dirtyharry
Thanks cliffy
I might have a connector already, but I'll almost certainly have to get back to you on the firmware and pdfs Bow down
Looks like fun times ahead! Very Happy Cheers
Greg
Previous vehicles:-
Post #168864 30th Jan 2013 6:48pm
