![]() | Home > In Car Electronics (L322) > Screen goes blank? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8130 ![]() ![]() ![]() |
If you've checked all the connectors, then a battery disconnect/reconnect is worth a go. |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
It a brand new battery only fitted beginning of December!
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Mine does do a "reset" every now and then, but no more than once a week, and only once at a time.
It doesn't seem to reset as the radio still works when the screen is blank!
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3987 ![]() ![]() ![]() |
I would try wiggleing (?) each of the various plugs about whilst watching the screen to see if it comes on, including the sat nav connections.
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
What sat nav do you have RANGE ROVER 04 TD6
I've just fitted a mk4 from Baris a month or so ago! |
It's your sat nav that's the problem
No it sounds like normal??? (As when I first put it in)
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 ![]() ![]() ![]() |
Mine does the same with a mk3, my mk4 got water damage so had to drop in the old unit and straight away it started doing the on off routine |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
A few things can cause this.
Thanks Baris, ill prob send the amp at the same time for upgrade etc!
Yes, take the blue connection from the tv tuner and plug it into the navigation drive.
No! The splash used to pop up fine but then one day I opened the door and nothing!! After a few mins the radio screen would pop up then disappear?
