![]() | Home > My Range Rover > Advice please - 2011 FFRR or New Disco4 |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
I had to have discs and pads on my RRS so i wouldn't think it was out of the ordinary.
Pads and discs are cheap enough. I aim for about 2-3 pad sets per disc set but found a set recently so cheap I changed the lot for £120 |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
thanks for the info.
No problems fella |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
There was also a recall for the battery lead mine was replaced when I had alarm problems.
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
It will be interesting to hear your thoughts when you have riven both.
Hi all,
If it was me I'd be asking an LR bodyshop to assess it and get a new bonnet on and sprayed as it sounds like water has got under the paint and if they try and repaint it after stripping it could come back if the metal had already started to react in places |
thanks.
6yr anti corrosion warranty should cover it completely unless stone chips caused it |
Can I insist on them replacing the bonnet? |
If it's rusting from under the paint I'd be asking for it. It would be the cheapest option otherwise they bed to strip all the paint off it, treat all the rust, flat it, prep it and paint it.. A day or two of work to do it right so worth getting an opinion from a good few local good body shops for their professional eyes on opinion |
Don't think I will get a chance to get independents to look at it first as the dealer is prepping from tomorrow and are based in Coventry while I'm in London.
My tyres were showing wear on the outer edges when I bought mine at 9,000 miles, I mentioned it and they booked the car into a specialist alignment place.
