Home > Off Topic > Computer question ?
Johnte
Computer question ?
My mum gave me a ring this morning, she had turned her laptop on, and it had come up with the message 'another computer on this network has the same ip address' she was worried about this, does she need to be Confused
Sorry, but I don't know about these things Whistle
Post #170205 5th Feb 2013 11:51am
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
it may be a smart phone, a tablet, a sky box.
you can log into the router and see specifics, then assign an ip per device if you want.
steve
Post #170206 5th Feb 2013 11:59am
TBH that shouldn't happen on a home network unless something has been assigned a static IP address...
Think of IP address's like the tickets at a meet counter or doctors. First come first served but if someone has mocked one up to jump the queue it can cause confusion... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170207 5th Feb 2013 12:05pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
The most important thing to do is check her WiFi (assuming she has one) is not being used by an authorised user.
Post #170209 5th Feb 2013 12:17pm
Johnte
Only thing I can think of, a few months ago she bought a smart TV. But if it had been this, would it have not brought the message up straight away?
Post #170210 5th Feb 2013 12:20pm
If she just wants it to go away - try powering off both the laptop & router, then switching them both back on again.
WiFi should have encryption/passwords etc or anyone can use it.
The default setting for most devices is to get an IP address dynamically allocated by the router when you connect to it. However, you can set a device to use a fixed address, in which case it's up to you to ensure that only 1 device uses each address.
It is possible that somehow her laptop is set to fixed IP and the router has already allocated that to another device (eg a phone, or the TV) so when she turns the laptop on, there is a conflict.
Post #170216 5th Feb 2013 1:27pm
