Home > Technical (L322) > Air Suspension Inactive
sk8tergirl
England 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi all
I have searched on the forum for this and tried to see if anything is applicable but nothing exactly yet
After the vehicle being stood for about 4 months without battery connection then being recharged and stood on a maintainance charger for about a month i drove it lastnight and have an air suspension inactive on the dash. i have turned it from lock to lock and also disconnected the battery for about 5 mins then reconnected but its still on and the suspension wont raise or lower by using the controller. it is in normal ride height and going for MOT today and I have been told that as long as it stays in road level it isnt a failure item it will be going for service soon at RR and I am worried i will have to have a new compressor which will be expensive
does anyone have any thoughts or ideas for a cure
PS I drove it for about half an hour lastnight and it didnt cure or alter
thanks in advance
Post #170426 6th Feb 2013 9:33am
You may need to get the fault codes read and cleared and see if the compressor kicks back into life.
If it doesnt then its time for a new one but they are silly priced, IIRC about £150-300 on ebay or the likes Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170429 6th Feb 2013 9:43am
What about disconnecting the battery and touching the leads together? That supposedly clears ecu codes sometimes and resets them.... Gotta be worth a try Thumbs Up Previously..
Post #170431 6th Feb 2013 9:46am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Where in Beds are you? I have RSW Allcomms. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #170558 6th Feb 2013 8:23pm
grant
I've got the Air suspension inactive message on mine - it's just appeared this morning. Does anybody know a good indy that could run a diagnostic? I'm near to Stanstead Airport.
Post #174215 24th Feb 2013 2:32pm
