Home > Technical (L322) > Towbar standard?
aneurysm1
2010 Range Rover Autobiography TDV8 Cairns Blue
Towbar standard?
Hi,
Can anyone tell me if a towbar is standard on a fullfat? Or do they have everything ready for one?
Thanks
Post #170837 7th Feb 2013 8:17pm
No they are not standard. Quite a few have them though
The oem westfalia bars are bolt on and the gen landrover wiring is plug and play so doable diy.
Have a search there is plenty on here about types and electrics. There is nothing that can't be fixed with a hammer😜😜
Post #170840 7th Feb 2013 8:26pm
aneurysm1
Thanks. I did do a search but didnt really find what i was after.
Apologies for posting in wrong section
Post #170858 7th Feb 2013 10:18pm
mzplcg
They are not standard but it's as easy as it could ever be to fit one. Even the hole in the body to allow the electrics into the boot is already in place. Electrics are plug in, no soldering or any of that silliness. Just buy the kit you want (13 pin, 7 pin or dual 7 pin) and off you pop.
Main towbar beam is standard item and then you have a 2" square receiver for your choice of hitch, i.e a socket for the removeable swan-neck, a height adjustable farmer's style hitch, or if you really want one, a US style 2" extension bar with a 2" ball.
The genuine Land Rover one (in case you're tempted) is made by Westfalia. If you buy Westfalia on line you will get it for way less than LR will charge you.
Post #170876 8th Feb 2013 7:32am
aneurysm1
Thanks for that folks. Ill see if i can get a tow bar thrown into the deal when i buy one. Testing 1 tomorrow in fact! Woohoo!
Post #170926 8th Feb 2013 11:41am
you might be lucky and have this,
if so , you're half way there.. ... - .- -.
Post #170929 8th Feb 2013 11:43am
aneurysm1
I wil have a look Stan, thanks
Post #170932 8th Feb 2013 11:49am
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
If not PF Jones in Manchester is the best provider local Thumbs Up
Just buy what you want and DIY, or I can do it for you Whistle
Post #170965 8th Feb 2013 3:11pm
aneurysm1
Thanks nbunney Thumbs Up
I suppose a car that hasnt towed isnt a bad thing, less strain through the 'box etc
Post #170988 8th Feb 2013 7:30pm
Andy
How much of a job is it to convert the two 7 pin plugs to the newer 13 pin single plug?
Post #171043 8th Feb 2013 11:51pm
mzplcg
Change of loom + 2 x 13mm bolts. Remove spare wheel if you have fat hands or use small child instead. 15 minute job.
Post #171051 9th Feb 2013 7:00am
Andy
This loom - is it a Land Rover part?
Post #171140 9th Feb 2013 3:25pm
Yes, landy part, give dan a prod for a price. There is nothing that can't be fixed with a hammer😜😜
Post #171156 9th Feb 2013 5:11pm
nbunney
PF Jones will do 1 a lot cheaper Thumbs Up
Even cheaper than double 7 pin Rolling Eyes
http://www.pfjones.co.uk/range-rover-13-pi...13-en.html
Post #171264 10th Feb 2013 11:15am
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
Anyone tried one of those adapters that sell for about £10 ?
Post #182661 13th Apr 2013 7:08am
