Home > Technical (L322) > Air Suspension - Extra modes Crawl & Extended ?
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
I've searched both terms without coming up with a thread on it.
I've stumbled across the terms 'Crawl' and 'Extended' referring to extrteme low and high suspension settings (below and above the regular maximum settings)
Anyone know how we can force them into these modes?
On a RRS Apparently you can stand on the brake in OffRoad mode and hold the Up switch foir 3 seconds to get an extra 1.5in? L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #171606 12th Feb 2013 4:55am
this was talked about many moons ago , i cant remember what the result was..... have you tried the RRS procedure on yours? ... - .- -.
Post #171624 12th Feb 2013 9:51am
found a thread via search..
http://www.fullfatrr.com/forum/topic5108.h...ended+mode ... - .- -.
Post #171625 12th Feb 2013 9:53am
As per the thread it needs to sense its being grounded to go up.
Will need to try the super extended bit next time myself, though someone with the older system should try it as well as my AS system will be the same as the one in the thread Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #171631 12th Feb 2013 10:06am
robjp
Wales 2004 Range Rover Vogue Td6 Zambezi Silver
For 'crawl' mode, you can select the 'Access' height and wait until it has set itself, press the centre button to lock, and then the suspension will stay in that height. I believe that going over 21 (or maybe 25) mph will cancel it anyway, and go back to 'normal' height, but would need to check the manual
Post #171653 12th Feb 2013 11:49am
CBH25
Thanks for the replies all.
Stan: Awesome thread nice find thanks for going to the trouble.
Robjp: Are you saying that Crawl mode ISNT lower than Access - its just locked at Access height? I thought it was a lower settiing? L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
Post #171903 13th Feb 2013 2:54am
robjp
Hi. According to everything I've read - and the owner's handbook, yes, access = crawl.
Very happy to be corrected though, there may be some way of bump-stopping the suspension if needed.
Post #171916 13th Feb 2013 9:49am
Flashman
Crawl mode is very useful when driving in some multi storey car parks. Tom
Current Drive
Previous Drives
Post #171922 13th Feb 2013 10:40am
