![]() | Home > General > Starting TDV8 when very cold; anyone have any experience? |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 803 ![]() ![]() ![]() |
Let me put it this way.......
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
I got mine from page 526 of 777, a bit further on from your section I think?
In theory.... If you disabled the valve it would heat the whole engine, maybe not to full operating temp, but prolly to 50 degrees easily?
claud Member Since: 15 Apr 2009 Location: Godalming Posts: 103 ![]() ![]() ![]() |
I agree with JMC, the FBH only warms the cabin, I use it every day in the winter plipping the remote just before I get dressed and drive to work. Even when it has run for 30 minutes (waiting for Mrs Claud!!) the engine temperature is cold.
Modern Desisals are thermaly very eficiant but the irony of this is it takes them along time to warm up when they are cold, and when they run cold the emit alot more noxious gasses. To counter this a FBH is fitter to all Land Rover engines to bring them up to temprature for emisions reasons. This heater can also but not exclusivly be used to heat the cabin. It was this function tha D3 owners were all after until they found the Webasto control unit. The way I see it is a solanoid vave is fitted to speed up cabin heating when this alone is needed but what it can't do is pre heat the engine block. 2008 MY Supercharged
My info was obviously duff then, as the TDV8 isn't covered in RAVE and they have obviously changed the FBH setup. On a related note I have an electric pre-heater I'm about to install when I can find a suitable place to fit it. Dan ![]() Last edited by dan_uk_1984 on 16th Feb 2010 4:19pm. Edited 1 time in total |
what's one of those? ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top 1998 90 TUL FFR Hard Top XD Wolf 1993 90 Tdi *Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
Lol, spell check fail. ![]() |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 ![]() ![]() ![]() |
I was in Aviemore late last year where it -17oC. The car usually started within 2-3 of turns. Before getting to Aviemore, I topped up the oil with Castrol Edge 0W-40 which the manual suggested for temperatures up to -35oC. Not sure how much of a help it was but it seemed to do the trick. The windscreen washers froze up though.
Hi I am back from the Alps and minus 20 c - I can confirm that it only seems to heat the TDV8 cabin and clears windscreen etc. Very toasty after just a few minutes. Mine starts first turn even down to -20 c.
Yes that's how mine seams to work.Now I need to ask my Dad if it is the same on his 2010 Vogue SE.
In my opinion anybody having starting problems should: 1. Get car serviced if that nearly due. 2. Buy a new and heavy duty battery. Range Rovers are all about having a good battery ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
think a lot of it is people buying FFRR and then trying to run on a budget, a goosed battery is a goosed battery - would need replacing sooner or later.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Mine says "aux ventilation" in the menu and I had a play with it when I bought it, but it just blew cold air. Never tried it since. I have noticed sometimes when I start it, the text "pre-heating" displayed on the dash but I disregard it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
