Home > Maintenance & Mods (L322) > 2010 nas spec sidelight markers removal UPDATED and sorted
Stuart's the man
Hi
i have got a set of 2010 nas spec rear lights.Has anyone disabled the side markers on them. not sure if you could drill a hole in from the back to burst the bulb. just wanting to know if anyone has any ideas
Post #172627 16th Feb 2013 10:48am
There is an LED inside and no access to the inside of the light as there is no bulb holder (due to no bulbs)
Post #172628 16th Feb 2013 10:51am
Stuart's the man
As you all know it is sometimed easier and cheaper to pick up a set of 2010 spec rear lights NAS spec. these all come with side marker lights, which is not to everyones taste, and it just screams ive been converted. mine were annoying me , so here is the fix.
Measuring from the top edge of the light on the back measure down 130mm, and then in 35mm. drill a 6mm hole and this takes you into the back of the circuit board where you find the bulb that is the marker light, break the connection going to the bulb. Problem sorted.and no effects from this
i drilled a 6mm hole as i had this size of grommet lying about, then ran a smear of sealer round edge of it
Post #173734 21st Feb 2013 12:28pm
