![]() | Home > Technical (L322) > Dreaded bing bong |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
You pre-empted my initial reaction, that the battery would be goosed, or the alternator is messing with the charge levels and spiking the sensors and making them trip.
Follow the chain:
Spend £20 at an Indy getting the hidden codes read with Testbook. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 780 ![]() ![]() |
This sounds very similar to the problem that I've very recently had with my early TDV8, the clue could be with the mention of a fault code relating to fuel pressure. There is a Landrover fix SSM44729 which relates to the connection on the fuel pressure sensor, this may be relevant to you. I'll send you this document if you think it might help you.
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 ![]() ![]() ![]() |
Sounds like a sensor fault if its clearing on restart. If there was a major mechanical failure, it simply wouldnt fix itself by turning a key on off, you'll most likely find a micro circuit is broken and the change in temperature on start up is causing the issue, the metal will be contracted when cold and as the car warms up, everything expands breaking the circuit temporarily this is why its happening in the firsg 10 minutes as your car comes up to temperature, where the fault is, is anyones guess, Id start at the in engine bay due to the multitude of systems affected '55 Java Black Vogue |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Hi Cass,
Can you PM me your email address and I'll send you the document as an attachment - I'd post it on here but I don't know how to upload it.
PM sent |
Just a quick update:
Picked up my car yesterday from Independent Land Rover Preston and so far so good. Repaired fuel pump installed and no warning messages after three trips made so far.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35813 ![]() ![]() |
sounds like a result... |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
I had the dreaded FFRR bong today...Outside Temperature 1.5c |
