![]() | Home > Maintenance & Mods (L322) > Leather care |
Yes it's very good especially the smell much better than the Autoglym |
DaWalley Member Since: 24 Jan 2013 Location: Cheshire Posts: 42 ![]() ![]() ![]() |
Cheers! I know this prob sounds naive but cause its cheaper than autoglym, I assumed it would be inferior. I think I'll get it ordered! RR Vogue TDV8 08 |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
Once you realise that the surface of the leather is sealed with polyurethane, you can make a more informed opinion about "feeding" it with conditioners and so on. |
The Gliptone seems to have done the trick on mine. When I got it it was cracking quite badly and now it is doing well. Considering that I live in Nigeria (heat/humidity/UV) that is not that bad. MY 2010 5.0 SC Galway green and sand interior!!
roger 47 Member Since: 24 Aug 2012 Location: Exmoor Somerset Posts: 80 ![]() ![]() ![]() |
"Furniture Clinic" Check their website. I use them and they are very good, they will also advise you over the phone if you have a problem. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8, 2017 L405 Autobiography
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
i used cliptone and found it was excellent id tried lorts of others and found this the only one that does what it says on the tin think i got mine from leather world online or was it world of leather ??? |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
just ordered gliptone leather cleaner and shampoo
