![]() | Home > Maintenance & Mods (L322) > Rear doors locking fault and steering. FIXED!!! |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Deffo the bcu. U could try a second hand one on eBay for £100ish. Make sure it’s the part number impending 22.
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
Yep, +1 for BCM. Second hand is more trouble than it's worth. I think the module stores data like mileage etc. So it's a pain to change it to another car. Then of course you could be doing it again in 6 months. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
| doclees Member Since: 24 Jun 2015 Location: PA Posts: 672
I'd pull a rear door lock and test power it. I did with a 9v battery. PO bought the beast with about 100k miles and bother rears and drivers door locks were dead. If you can get 10 or more cycles without a fault then I would assume the locks are good. Also if you love the truck think about investing in an iidtool. Worth every penny. |
| bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 455
I agree with Grofus and Dolphinboy - it sounds like a typical BCM problem
| Ken_Curtis Member Since: 24 Dec 2017 Location: Up North Lad Posts: 13
Thanks for the reply.
Hi All
If £300 includes the module, then it's very reasonable. Hopefully you won't need it for a while yet.
I bought my new BCM from Ducky Dan - site sponsor "duckworthparts". He was the cheapest I found.
Many thanks for the replies.
Use a good Indie and it's about an hour's labour. £40- £60 should cover it. If you have a gap iid BT I think you can do it yourself. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Well, I thought the reset had fixed it but the gremlins have returned with a vengeance today.
Hi All
I got called back and the car is booked in this Friday morning to get it plugged in to a diagnostic machine to verify 100% its the BCM causing the issue and rule out wiring.
Sounds like a proper plan. I'd assume these suffer bad solder joints from vibration over time. Unless it got drowned at some point. |
