Home > Maintenance & Mods (L322) > Annoying repair!
daveym
United Arab Emirates
Annoying repair!
I've just finished from replacing the ignitor in the n/s headlight. It has to be the most annoying repair I've done to date! First of all seized bolt preventing the headlamp being taken out then when it is out trying to figure out to get to the gibbons of the electrics inside. With patience and a lot of cursing I eventually removed two diddly bolts freeing up the ignitor. The it gets even more annoying putting the new unit in.
Now my question is what's been the most annoying / fiddly job to date on the Rover?
Post #177674 14th Mar 2013 10:22pm
you've been unlucky then cos mine went smoothly.. ... - .- -.
Post #177677 14th Mar 2013 10:49pm
Googsy
Cooking my headlights for the 8th time Censored Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #177684 14th Mar 2013 11:26pm
T24RES
Fitting the side tubes. The threads in the body required re-cutting, fiddly but not the end of the world. Fitting the tow bar was more time consuming.
Post #178204 18th Mar 2013 3:50pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I'm surprised at you having problems fitting the ignitor - I did both sides on mine last year wearing a suit - the pars were delivered to work, so I nipped out at lunchtime and fitted them. I reckon it took no more than 15 minutes a side - and I didn't remove the headlamps to do it.
Post #178401 19th Mar 2013 3:43pm
daveym
I didn't replace the silver ballast that is held on with 3 torx screws - I replaced the actual ignitor cable that runs to a small black box housed within the headlight.
Post #178560 19th Mar 2013 11:11pm
