Home > Maintenance & Mods (L322) > Privacy glass |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
Easiest way to tell - can you clearly see the rear screen heater elements from the outside of the car ? If clearly can be seen then this is likely yo be film and can be removed with a hair dryer. If cannot be seen clearly and you have to look really hard into the glass to to see them then this is factory tint and cannnot be removed 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
18th Mar 2013 9:14pm |
Assuming you want to remove film if fitted, drag a sharp nail across the inside surface of a side window. Tinted film will mark, glass won't. |
18th Mar 2013 9:19pm |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Ok will check tomorrow. Was privacy glass standard on some of the early l332 vogues? |
18th Mar 2013 10:10pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Factory privacy was an option from 2002. |
18th Mar 2013 10:34pm |
It's factory glass so not much can be done abut it. |
1st Apr 2013 2:05pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
1st Apr 2013 7:42pm |
If it can be broken with a hammer... |
1st Apr 2013 7:44pm |
park it in a dodgy area next to a pile of bricks....... Wish mine was factory, looks ok just one of those things which bugs me.
2nd Apr 2013 5:49pm |
I'm in two minds. Sometimes I prefer the look of the green tinted all round... |
2nd Apr 2013 6:22pm |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
I have come to the conclusion that when the first ball joint or bush wears out, its best policy to replace the lot on that axle. The chances are that the rest are not far behind and the effect if one bush or joint malfunctioning hastens the demise of the rest. May as well have one miserable makor expense, rather than the a catalogue of failures thAt feel like dripping tap torture. Do it all once and there is only one set up and finish cost. |
2nd Apr 2013 9:08pm |
