![]() | Home > Technical (L322) > EPB Adjustment (SOLVED - HOW TO INSIDE!) |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 926 ![]() ![]() |
EPB is self adjusting AFAIK. |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Found this from TOPIX
I didn't do this after changing my rear discs, maybe I need to do it - Has anyone done this? |
Just completed this procedure, works exactly how it says, now the EPB seems to be set up correctly, basically beforehand the EPB would hold the car whilst on a slope and in neutral and would hold the car while in reverse but not hold the car while in drive - now it works perfectly.
I did it with my manual handbrake after changing brake shoes.
This procedure seems to calculate and alter how much force is applied by the servo |
