Home > Technical (L322) > Center air vent unit problem
cubbyno9
United Kingdom 2013 Range Rover Vogue SE SDV8 Farallon Black
Hi guys, my top double air vent on the dash is not clicking home correctly. When i bought the car it was hanging off slightly and it has gradually got worse. The top is clicked in correctly but the bottom is hanging out about 1 cm. I can't push the bottom in enough to click shut. It feels as if it won't push home properly, as if something behind vent is stopping from clicking home. Or the bits on the vent are broken at the bottom where it clicks on.
Is this easy enough to fix if I can get another vent unit. Is it just the hazard on the other button (sorry can't remember what) that need disconnected ready for the new vent, thanks in advance.
Post #179242 23rd Mar 2013 2:10am
take it out completely and have a look, probably something very simple.. ... - .- -.
Post #179271 23rd Mar 2013 10:47am
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
If you run a search on here i think there is a common issue regarding a little clip that holds one of the adjusters (possibly a cable, im not sure as i haven't personally had one apart yet.)
Post #179343 23rd Mar 2013 3:37pm
cubbyno9
hi,thanks guys, I will have a go at it.
Incase the clips are broken any recomendations to anywhere I can get a replacement other than going dirrect to LR, cheers.
Post #179396 23rd Mar 2013 9:35pm
