![]() | Home > Technical (L322) > Help with a gearbox fault |
adesmith Member Since: 06 Feb 2013 Location: Cheshire Posts: 46 ![]() ![]() ![]() |
I have no idea to be honest but if you watch Wheeler Dealers the other week Mike Brewer had that issue with a Porsche Boxster and an oil change of the gearbox resolved it. |
Have you checked the gearlever mechanism and electrical connector(s) to the box ?? MY 2010 5.0 SC Galway green and sand interior!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35814 ![]() ![]() |
this might help,
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1026 ![]() ![]() |
That certainly is strange. In first gear the coast and forward clutches are engaged and the only difference between ‘D’ and ‘Manual’ is that in manual mode the Low/Reverse clutch is additionally applied to bypass the low clutch sprag. The implication therefore is that something has happened to your low clutch sprag, causing it to work intermittently, but it’s hard to see how a rear-end shunt could have caused that?
madpugger Member Since: 07 Feb 2013 Location: Aberdeenshire Posts: 49 ![]() ![]() |
Thanks guys
Holy moly that is a lot of energy to be dissipated. I would talk to the insurance company and claim a new gearbox because that is likely to have done serious damage to it. MY 2010 5.0 SC Galway green and sand interior!!
Yeah there is a lengthy insurance saga going on... They want to write it off but there's no way that's happening! I'd rather fix something than replace it... We'll investigate and find the cause but it's always nice to hear if someone has BTDT... |
Great to know the RR is that solid. Although for energy absorption it is not that great apparently. Still the Corolla crumple zones did a lot of absorbing I guess |
Looks like we found the cause, a failed Sprag bearing.
Glad to hear you found the cause and glad to hear that Phil was right |
Box went in last night, Transfer box half in too, so not much left before it can be tested! |
