![]() | Home > Technical (L322) > Air Suspension Height Anomaly |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
Disconnect the battery for 15 mins then once reconnected turn steering wheel full lock left to right? This may help?? |
rgwatches Member Since: 19 Dec 2012 Location: United Kingdom Posts: 36 ![]() ![]() ![]() |
Thanks, I've tried all the normal old tricks to no avail. |
Not wanting to sound stupid, are you parking on level ground! After parking on a slope mine was on the wonky until i drove it again!
It's on all surfaces, I think the unsuccessful re calibration has caused the issue, I just need to know how to go back a step. |
Battery disconnect resets it?
Already tried it, no joy.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35813 ![]() ![]() |
i would email storey and ask how to get it back to stock.. ... - .- -.
The software is up to date, might just pop to RCV and let them manually reset it with their super duper computer. |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
I had a similar problem when I calibrated my suspension using RSW Allcomms. The whole car just seemed too high and measurements confirmed it. Figured I had been measuring and calculating the values to enter into the software incorrectly, perhaps because i seem to be the only one left in thrld running on 18" rims. i just 'fudged' the values. In my case, everything seemed to be about 2" too high - so I just added 50mm to the values I entered in the software. Worked a treat. Hope this is of some help. Current: 2010 Range Rover L322
Many thanks, I'll give it another whirl, basically on mine I click get heights, input the respective values then hit calibrate and it does nothing, I might have to go back to RSW as it may be a fault with the software. |
This chart may help you ( I run 18"s in the winter/summer)
Many thanks, I'll have a go tomorrow and report back. |
Your a star, checked the faults (none) and ran through the procedure again and it worked!!
