![]() | Home > Technical (L322) > Battery going flat? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
You have a current drain which is unacceptably high at 150mA, should be a lot lower.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35814 ![]() ![]() |
Graham , this is an interesting thread that has the same problem as you..i would put aside a few hours and have a read..
ggdtr5 Member Since: 22 Jul 2009 Location: Aberdeenshire Posts: 13 ![]() ![]() |
I have now got to the bottom of this now.
Fuse 37 should only be fitted if towing the car.
i got my battery from ECP and had a problem more or less a year later and they replaced it without any quibbles.. ... - .- -.
I think you are ok with a reputable supplier of batteries regarding battery guarantees, internet supplier, possibly questionable. |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
Unless there was something in the guarantee which specifically excluded the use of the battery on the L322, or reduced then length of cover when fitted to the L322 due to this "known fault" then I can't see that they have a case.
The battery came from the carbatteryshop they said they had a number of batteries returned which had been fitted to range rovers so without any diagnosis they had decided the car was at fault. They tried to justify this by saying if the battery had been frequently run flat then it would damage the plates -huh!!! Now then, how many batteries are run flat throughout their life -you don't just need a fault on the car and how many people have inadvertently left lights on draining the battery, quite a lot i think. Anyway I had only run the battery flat once and if this it all takes to goose a battery then I would suggest the battery is not fit for purpose. But then what the hell do I know!!
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Re the headlamp wash, I was told the same thing by a land rover specialist a few weeks ago when my Bosch 110a battery packed up. First of all they weren't exactly horizontal when in the parked position- just a few mill up from park to be honest. However, if they are like that, they are constantly drawing power. For some reason, they stopped working as well and went on to fail the MOT. When the car was jump started by the rac for the third time in a fortnight, the wipers started working and parked correctly after that.
