Home > Technical (L322) > Pagid front pads/discs sound like a conch blowing
T24RES
As per the title. New pagid discs and pads 3k ago. They are really good, feel, response, etc.
they do however make an awful noise at very low speed when you are just rolling in slow traffic, sounds like a conch being blown. Very irritating.
Any solution or suggestions from the masses?
Post #180503 30th Mar 2013 9:00pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Are they standard vented or cross drilled/grooved?
Also is the noise coming from the rear of the front?
Post #180505 30th Mar 2013 9:07pm
probably need a bit more copper slip on them. There is nothing that can't be fixed with a hammer😜😜
Post #180506 30th Mar 2013 9:20pm
My Mintex with dimpled & grooved squeeled like a pig at low speed. A few high speed all out stops from 70>0 sorted it. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #180507 30th Mar 2013 9:25pm
T24RES
Standard, vented fronts.
Post #180552 31st Mar 2013 9:53am
On a long straight private road get upto about 60-70 and brake hard and down to an almost stop without instigating the ABS a few times. This will clear any glaze off the pads and helps a little with slightly warped discs IME.
The key is to avoid the abs kicking in as once it does that the pads are just sticking to the discs then. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #180608 31st Mar 2013 8:12pm
