![]() | Home > Technical (L322) > Swapping Xenon to non-xenon headlights |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263 ![]() ![]() ![]() |
Why? ...just switch them to lhd. It only takes 5 minutes
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35814 ![]() ![]() |
fullfats have a little lever in the headlight enclosure that when switched allows us to drive in france etc.....as said switch this over for the test.. ... - .- -.
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
From memory you have to have a LHD beam pattern to register a car in France - the headlamp shutter lever masks off the RHD nearside high lights (which normally light up the kerb/ pavement) - but it doesn't give you a proper LHD beam (just a flattened RHD beam). |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Exactly right VagelyVogue the light go from RHD to flat beams so as not to dazzle... To pass a french test they must be LHD lights...
Well both my BMW and TDV8 passed by just doing this.
jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66 ![]() ![]() ![]() |
Thanks for the input - seems like we have two different opinions re what is required to get through the French CT! Will probably ask my friendly CT man to take a look before I spend €€€ on new lights.
Sorry guys
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi
In between Bergerac and Perigeaux....and you? |
I'm in the Perigord, so more apples and Fois Gras than cheese.... right up in the north east corner of the Dordogne.
Non, they will not fit unless you get the whole kit kit if you want to get a 2006/2009 facelift (got it all)
I sense a wine session |
